Old 12-27-2008, 11:19 AM   #1
lavmech23 is on a distinguished road
Please help 2003 dodge diesel issues
I have alot of trouble getting it to start when its cold, at first i would keep it plugged in and it would start fine in the morning now after having it plugged in it just turns over, replaced the batteries and still having trouble any suggestions would be great.
lavmech23 is offline   Reply With Quote
Old 12-27-2008, 11:51 AM   #2
welcome to the forum
is your block heater still working? have you checked the glow plugs? not knowing where you are, are you using seasoned fuel with additives? when was the fuel filter changed last?
leolkfrm is online now   Reply With Quote
Old 12-27-2008, 04:07 PM   #3
batty1214's Avatar
are you cold enough to have to worry about diesel fuel gelling up? we have gelled up quite a bit of stuff here...... do you know if you are running a winter blend or not?
Old 02-17-2009, 01:57 PM   #4
terrywerm's Avatar
terrywerm is on a distinguished road
I would start by checking a couple of things:
First your block heater. When you plug it in or unplug it, you should see a bit of a spark and hear a quick crackling noise as you do so, especially when you unplug it. If you don't get either of those, you may need to replace your block heater cord, or the heater itself. Block heaters are generally pretty durable, and will last a very long time as long as they have not been overheated (left plugged in with REALLY low cooland level.)
Make sure that your intake heater grids are working. The heaters themselves are pretty reliable, but each of the grids has its own relay. Make sure that the relays are energizing the grids. You can ususally tell if they are working correctly by watching your voltmeter closely for a few minutes after starting the engine cold. After starting you should see the volt meter drop from 14 down to about 12 volts and hang there for a little bit, then it will start to come back up to 14. It will cycle back and forth like this for several minutes. If the voltage does not drop at all, your intake heaters are not working and you will have to dig further to find out if the problem is with the relays or the heaters themselves.
Not sure where you are located or how cold it gets there, but my 01 diesel RAM will normally start after sitting for ten to twelve hours, not plugged in, and temps around 0, and I still have my original factory batteries (they are in need of replacement, which I expect to do soon.) Usually I plug it in when it's that cold, but sometimes I don't have a choice.
Terry
Real trucks rattle!
'01.5 Dodge Ram, QC, SB, 4x4, 5.9 CTD, 5 Spd
'99 Dutchmen 30' 5th wheel
'87 Jeep YJ, 6 cyl, 5 spd (project)
terrywerm is offline   Reply With Quote
Old 02-17-2009, 03:14 PM   #5
another one terry, notice he never answered us?
2003 Dodge A/C fan problems russell8 Dodge Truck Forum 4 05-20-2008 07:53 PM
Electrical Issues 2003 GMC Yukon XL Canuck78 GMC Truck Forum 0 03-12-2007 03:10 PM
2003 dodge ram 1500 sb,cc marrsbarak Dodge Truck Forum 0 12-19-2006 11:45 AM
2003 6.0 Diesel Johnny Rotten Ford Truck Forum 2 12-05-2006 02:20 PM
