| Junior Member Join Date: Feb 2009
| I have a 1998 Ram 1500, 4WD, AT. The truck suddenly began to ping, like a lean fuel pinging, when I would accelerate. When I back off, the pinging stops. The scanner read MISFIRE CYLINDER EIGHT I use premium gas. I have already changed the cat/converter; the plenum pan gasket; cap and rotor. I checked the wires and plugs (recently installed), they appeared to be okay. I did a compression test on the #8 cylinder, and it was fine. I heard of an older Mopar TSB regarding reprogramming the PCM due to these exact symptoms. Any thoughts? This is my ride for both highway to work and off roading. Help!! Today, 02/22/09, when I accelerated, the Check Engine light would flash; when I got off the pedal and simply cruised, it stayed steady on. This happened every time. ???????????????????????????????? Last edited by Tagman; 02-22-2009 at 03:01 PM. |
| bad/week injector ? maybe . lock through this might help . shd |
| does it smoke when you start it? i had this problem, it was my plenum gasket under the intake manifold....replaced and now it works fine....what happens is the oil seeps in the plenum gasket and runs down into the cylinders and fouls the plugs..... mine was both back cylinders. plenum and intake gaskets were like 24$ i also put a n new water pump on at the same time....if you need help , let me know! |
| Last Activity: 02-22-2009 maybe he dont want our help. |
| Check Engine Light | Doktor Rocket | Chevy Truck Forum | 3 | 09-30-2008 10:46 AM |
| Check engine light | arthur66 | Chevy Truck Forum | 4 | 07-30-2008 02:28 PM |
| check engine light | jlsavoy | Dodge Truck Forum | 5 | 04-19-2008 11:45 PM |
| check engine light | topkat | Mazda Truck Forum | 2 | 12-31-2006 05:37 AM |
| Check Engine light and overdrive light on | chief | Introductions | 0 | 02-05-2006 08:12 AM |
