| Junior Member Join Date: Apr 2009
| 2001 ram 1500 5.9 4speed auto bad !!!! At 120000 miles i was driving the interstate and overdrive kicked out , a few miles later trans temp lite went on. i imediatly pulled over and shut down the truck for 30 minites. i noticed fluid leaking from the front of the trans . after cooling down drove slowly home , while driving i put the trans into neutral when i could to keep fluid moving but not using trans. my shop guy flushed out trans and removed check valve. truck worked fine for about 500 miles no leaks . then while driving 3rd gear went out , all i had was 1st and reverse ! no trans temp lite ! while limping home i would occasionally go into 3rd them i would lose it again ! so i changed the filter and fluid (atf+4) and took it for a test drive . it shifted fine for about 2 miles , then 3rd was gone again ! just 1st and reverse. i checked the cooling lines both were cold ! when i changed the fluid i blow out the lines till no trans fluid came out . i also tried to blow compressed air into the line conection on the trans the top connection would accept air to a point then blow fluid back out . the lower would not take any air , like there was a one way valve ? is the trans toast or should i check something else ? i also have a p1740 code coming up . thanks for your help !! |
| welcome to the forum sounds like it is rebuild time
| rebuild ?!?!?! are there updates for the rebuild that dodge forgot when they built the piece of s**t ? |
| Full Member Join Date: Apr 2009
| Tee into a transmission cooler line with a pressure gauge. Actuate lock up with the DRBIIIŽ. Pressure should go up 5 to 10 PSI when lock up is requested. If it does look at possible problems with the torque converter, front pump, input shaft and seal rings. If pressure does not go up look at the transmission solenoids. i no you may not have acces to a DRBIII sounds like an electrical issue in the valve body or the TC ... ? I do not think the tranny is junk yet because you have the 5.9L comes with a beefer transsmission but i would take care of it right away if its the solonoid it cost only 95 bucks and is easy acces.. |
| Occasional Brake Troubles in 2001 Chevy Silverado 1500 | fabformula | Chevy Truck Forum | 4 | 10-10-2008 12:26 PM |
| front wheel bearing/hub assembly on a 2001 Dodge Ram 1500 | Space Ace | Dodge Truck Forum | 10 | 10-09-2008 09:38 AM |
| 2001 Dodge Ram 1500 Reg. Cab | cghost88 | Dodge Truck Forum | 2 | 09-29-2008 08:55 AM |
| 2001 Ram 1500 front axle woes | metal cowboy | Dodge Truck Forum | 1 | 08-12-2008 10:25 PM |
| 2001 1500 mod information? | rickards | Chevy Truck Forum | 1 | 06-20-2005 12:08 AM |
