| 1998 dodge transmission temp. light...HELP! I just put a used tranny in my 1998 4 wheel drive with 5.9. works great, the trans. temp light and the O/D off light keep coming on.....seems to be random, I blew the cooler out , that was fine, the check valve operates fine, my dad has a computer.....said engine temp was 212, trans temp was 298....however when i touch the engine oil pan, it is hotter than the transmission pan..... i think it is a faulty sensor......because of this that it is random. i drive it ten miles....lights are on.....shut it off run an errand , get back in........it is off again....then my overdrive switch works ....anyone have any clues? where is the temp sensor? |
| 1998 Ram 1500 Lean gas ping/Check Engine Light | Tagman | Dodge Truck Forum | 3 | 05-16-2009 07:37 PM |
| 1998 Dodge Ram Brake Problem | leelee7919 | Dodge Truck Forum | 2 | 04-17-2008 10:36 AM |
| Transmission Temp | shenguy | Chevy Truck Forum | 5 | 03-14-2008 04:28 PM |
| Transmission Temp question | dpritts | GMC Truck Forum | 2 | 11-12-2007 11:19 PM |
| Service Engine Light-transaxle temp circuit grounded | rockitman | Chevy Truck Forum | 1 | 11-21-2005 03:23 PM |
