| Looking for some help with a starting problem with my 78 dodge truck. Machine has 80K , carburated, 400ci. Has been drop dead dependable untill the last month or so. Was driving early morning and it just died!! Would not start. Turned over fine but acted like it was getting no fire. I can get it to fire right up with the outside temp is 70 or above. If it's below that you can crank it till the battery dies and it will not start. The choke sets just like it should. It's getting gas , in fact it will flood it you're not careful. If it's over 70 degrees it will fire up on the first crank, no spitting or sputtering. Idles smooth as silk.?? I'm getting fire to the distributor. Getting gas to the carb??? WTF is going on. Any ideas would be greatly appreciated. |
| how do the points look?
| did you check the coil resistor?
| starting problem checked this out this morning at 7am. Temp about 60 degrees. Checked to see if coil was firing--no spark. Came back home at 12:00 checked again. Outside temp around 85. Now I'm getting spark???!! WTF ![]() |
| check to make sure you dont have condensation building up in your cap when its cold. but....sounds like the coil is your problem. |
| Junior Member Join Date: Sep 2009 Location: Royston, Ga.
| It is thew ignition module located on the firewall, it has a plug with 5 or so wires on it. Mine would go out every so often. |
| FYI insanehewey prospector1649's info Last Activity: 05-20-2009 10:59 AM Join Date: 05-19-2009 Referrals: 0
| Starting it?? | gettembuilt | Ford Truck Forum | 5 | 02-19-2009 07:59 AM |
| 98 dodge dakota charging issue | 87bimmer325 | Dodge Truck Forum | 10 | 02-07-2009 04:14 PM |
| 1999 Dodge problems starting | ThorRacing | Dodge Truck Forum | 5 | 10-13-2008 02:36 PM |
| 2007 Thunder Road Dodge Ram 1500 4x4 Issue | dodidupa | Dodge Truck Forum | 2 | 03-07-2007 08:36 AM |
| Starting Issue | LDP787 | Chevy Truck Forum | 4 | 01-16-2006 01:01 PM |
