Old 06-27-2009, 07:58 PM   #1
Leroy is on a distinguished road
Engine Just Quit Running
'97 Dodge Ram 1500 4x4 5.9L... I was driving down the road and the darn thing just died. Lucky I was pulling into a gas station. Couldn't get it to start, checked the fuel pump and it is pumping good. The tow truck driver said it could be the crank shaft position sensor. All plugs, wires, dist. cap, rotor have been replaced in the last 6 months.
Leroy is offline   Reply With Quote
Old 06-27-2009, 08:07 PM   #2
FaselZ71's Avatar
First thing I'd do is get the egine codes and start from there... Crank sensor is plausible however that's just a quick assumsion I'm sure from a tow truck driver trying to sound smart... However I'm sure the engine codes with tell you what's wrong if it's possible they scan for free at Autozone and Advance auto parts. If it's not possible then I'm affraid your in a game of cat and mouse chasing problems... Could be as simple as a sensor or as complex as the computer. If you had a OBD1 get codes would be simple unfortunalty you have OBDII so it's not that easy. I'm sorry I couldn't be more help.
Old 06-27-2009, 08:10 PM   #3
z07
z07's Avatar
If you have spark but the injectors are not pulsing then the crank position sensor is a good place to look.
It is mounted to the top driver side of the bellhousing and you will need nible hands or a sciencefair project of swivels to reach it from underneith and below the trans.
If you backprobe it with the key on engine off you should find one wire with 5 volts one wire is ground and the other wire has nothing. Move the volt meter to the ground and nothing wire and watch your analog meter as someone cranks the motor. The needle should swing from 0 to 5 as the engine turns. If it doesn't then there's your problem.
You can reach the electrical connection for the CPS easy from the top driver side.
Old 06-27-2009, 10:02 PM   #4
stumpuller454's Avatar
check all your grounds too, i remember chasing one down for months, darn truck would only die on rough roads, but fire back up, was a ground on the firewall if i recall correctly....
Old 07-17-2009, 03:11 PM   #5
Changed crank position sensor, (what a pain that was) still wouldn't start. Replaced the coil.
Problem solved.
Lesson learned; don't listen to the tow truck driver!
Engine running bad at normal temp! Ernie R Chevy Truck Forum 8 03-30-2009 03:08 PM
Transmission quit. (HELP) gmctrucks GMC Truck Forum 8 04-16-2007 05:58 AM
engine stops running chief573 Chevy Truck Forum 2 07-30-2006 05:59 PM
Engine dying afte running a few mins. on 89 s-10 Polaris 500 Chevy Truck Forum 7 01-22-2006 04:05 PM
1993 Ranger quit running! krobb10 Ford Truck Forum 3 07-14-2005 09:21 PM
