Old 07-20-2009, 09:24 PM   #1
bobbyc1658 is on a distinguished road
Charcoal in the vacuum system?
I just tried to change the vacuum check valve on my 97 Dodge 1500 and found charcoal residue. Checked out the cannister under the driver side and found it had come all apart inside. What can I do to get the charcoal out of the system? Is there a way to flush the system? Originaal problem was tthe a/c blew only through the defrost and floor vents. Began to look at check valve as solution and found this. HELP!
bobbyc1658 is offline   Reply With Quote
Old 07-21-2009, 12:58 AM   #2
Welcome and howdy from TEXAS. I have no idea how to get rid of it sorry. Might buy a new canister or try Pick-A-Part.
Good luck! GMC
Old 07-21-2009, 06:42 AM   #3
wowsers. seems like i have seen a thread identical to this somewhere. might do a thread search on it.
Old 07-21-2009, 06:47 AM   #4
Yes Brad i think someone had this about six months ago, i believe they changed a lot of the smaller tubes and cleaned the larger ones
Old 07-22-2009, 02:21 AM   #5
jimbo543 has a spectacular aura aboutjimbo543 has a spectacular aura about
check with dealer for recall
jimbo543 is offline   Reply With Quote
Old 07-22-2009, 10:14 AM   #6
Charcoal in the system
Thanks for all the replies. I guess there is no easy way to clean the lines and valves. Just wondered if a solvent of any kind could be used?
Old 07-22-2009, 11:29 AM   #7
you can try using a solvent but for the cost of new lines, the work is not really worth it. vac line is cheap if you by it by a roll and just cut to fit. quick and easy doing it one line at a time.
Old 08-01-2009, 10:50 AM   #8
Dash is on a distinguished road
I had this same problem on a Toyota -- the charcoal canister was slowly self-destructing. I used a copper wire to clean some of the hoses but I still had to replace some of the hoses. I used a variety of cleaners with not very good results to try and clean the passages.
'71 Cadillac Eldorado convertible
'71 Karmann Ghia convertible
'89 Dodge W150 4x4
'92 Acura Legend
'02 Dodge Quadcab 4x4
Dash is offline   Reply With Quote
Vacuum leak detected MI0706 Dodge Truck Forum 10 06-24-2009 03:54 PM
Vacuum line diagram RangerJ Ford Truck Forum 3 03-07-2009 10:33 AM
vacuum prob austinpowers Chevy Truck Forum 5 09-08-2008 07:17 AM
vacuum problems geoemojr Chevy Truck Forum 6 12-19-2007 08:28 PM
vacuum problem worm Chevy Truck Forum 3 03-29-2006 09:00 PM
