| noise from rear end only at a low speed turn Hey gang, 2000 Dodge 1500 4wd. I get a whinning noise from the rear only when turning left or right at maybe 5mph, usually from a stop. I dont hear it going straight or at higher speeds. any help would be appreciated. Thanks. Last edited by mavic; 08-24-2009 at 12:42 PM. |
| you may have damadged spider gears in the differential, or a seizing up spider on the pin, what is the condition of your rear diff oil?
| thanks for the reply. just bought it used so i dont know. would changing the fluid be a waste of time? |
| it would if the spiders are already gone. take that little plastic/rubber cap off of the back of the pumpkin and see whats in there. |
| Rear end noise? Like a grinding noise. | markparks1 | GMC Truck Forum | 8 | 11-08-2008 09:20 AM |
| Brake light and rear turn signal problem? | aretevince | Mazda Truck Forum | 18 | 10-06-2008 07:12 PM |
| New Speed Sensor Making Noise | silverta16 | Chevy Truck Forum | 0 | 05-23-2008 07:18 PM |
| rear end noise | rcarlos | GMC Truck Forum | 9 | 03-06-2008 10:39 PM |
| Noise from rear end | Itstali25 | Chevy Truck Forum | 6 | 10-24-2005 09:31 AM |
