Old 11-30-2004, 12:36 PM   #1
runedawg is on a distinguished road
Angry Timing or Carb Issues ????
I have a 73 dodge truck with a 318 in it. It has the performance electronic ignition kit, summit street coil, and orange ignition module. Also it has an Edelbrock performer intake wit a Holly 600 4 barrel carb.
The prob im having is that it keeps backfiring through the carb and it tries to stay running when you turn the key off.
What causes this and what is the correct ignition timing for my set up
runedawg is offline   Reply With Quote
Old 12-14-2004, 03:39 PM   #2
joe rod is on a distinguished road
I don't know mutch about carbs. I do know about timing. Make sure you don't have a wire crossed and in the rite order, and make sure youre timing is on. If you're timing is off or a plugwire is crossed it will backfire.
The correct timing will be on the intake manafold. if it is not it is 1 8 4 3 6 5 7 2. start with #1 cylinder up and if it still backfires you might be half off on the timing.
joe rod is offline   Reply With Quote
Old 10-09-2005, 10:55 AM   #3
flntlokr is on a distinguished road
I just went thru the half off timing thing. It wouldn't run at all that way. (see the 'Dead Ram' thread) Run-on (dieselling) is usually due to super-rich mix which allows the engine to keep going for a while because the hot combustion chamber will ignite a rich compressed fuel mix without spark. Bad timing will also make it happen (late timing I think) and can also make for carb fires. Stick a vacuum gauge on it to help the diagnosis and tuning. And surely check the firing order just in case.
flntlokr is offline   Reply With Quote
Old 10-09-2005, 11:07 PM   #4
chevyguy's Avatar
Carb cannot cause any of the symptoms described above Sorry flntlokr, But this is a timing issue all the way, backfiring comes from improper ignition timing and dieseling comes from advanced ignition timing. Retard the distribiutor and yes using a vacuum gauge helps, but not required. Simple start the motor and turn the dist counter clockwise until the motor starts to bog down, turn to the center of the 2 positions and tighten it down,If you are unable to find a satisfactory timing setting then i susoect the motor has jumped time and it is time for a new timing belt, or just upgrading to a chevy motor.
USMC 92-96 USCG 98 to present
Old 11-05-2005, 02:11 PM   #5
fanbladez is on a distinguished road
well also backfiring and continueing to sputter after ignition is off could be bad gas i;ve had problems similar and thats what it was but just a guess on my part
fanbladez is offline   Reply With Quote
Old 11-05-2005, 04:19 PM   #6
chevyguy's Avatar
Correct, but very unlikely.Bad gas cannot cause backfiring though, This is a timing issue not a carb issue. Both symptoms point to timing. Is it backfiring thru the carb or thru the exhaust.
Old 11-05-2005, 04:20 PM   #7
Itstali25's Avatar
Itstali25 is on a distinguished road
^ I concur doctor
http://www.cardomain.com/ride/644045
Trucks are just cars when they grow up!!!
If your gunna get a truck....Get a TRUCK!!
Itstali25 is offline   Reply With Quote
Old 11-17-2005, 02:41 PM   #8
Truck_Man is on a distinguished road
Im thinking the timming is advanced to much.
Truck_Man is offline   Reply With Quote
Old 11-17-2005, 07:36 PM   #9
chevyguy's Avatar
Umm the timing would have to be reterdid too much since it is backfiring thru the carb. Advanced would be backfiring thru the exhaust.
Old 11-18-2005, 05:51 PM   #10
HVY84CHVY's Avatar
HVY84CHVY is on a distinguished road
chevy motors, LIKE A ROCK (to chevy guy) willl be around forever
HVY84CHVY is offline   Reply With Quote
carb problems F150on40's Ford Truck Forum 3 01-05-2005 07:52 PM
