Old 09-01-2009, 11:00 AM   #1
ridehard1 is on a distinguished road
Question '98 Dodge 1500
I have this problem with poor acceleration.The truck runs /idles rough at times. When I take off at a normal speed it backfires through the carb.If I feather the gas pedal and or floor it it will take off. I have replaced the plugs,wires,rotor cap,rotor and the fuel pump.That was costly. Does anyone have any idea what I need to do next,besides get a different truck!!
ridehard1 is offline   Reply With Quote
Old 09-01-2009, 11:04 AM   #2
Towtruck's Avatar
Towtruck has a spectacular aura aboutTowtruck has a spectacular aura about
Have you checked the ignition timing?
ASHES TO ASHES, DUST TO DUST, IF IT WEREN'T FOR CHEVY'S MY TOOLS WOULD RUST
Towtruck is offline   Reply With Quote
Old 09-01-2009, 02:05 PM   #3
98 Dodge
No I havent.I had it taken into the shop today. Hopefully they will find that and fix it without too much more cost. Thanks for the reply
Old 09-01-2009, 02:08 PM   #4
check timing, like mentioned and clean up the throttle body of carbon deposits paying close attention to the ports for your senors, the TPS and IAC located to the rear of the throttle body. also check the fuel regulator. it will be a shiny disc shaped apparatus located in the fuel line. this will cause similiar symptoms to what you are describing. they are fairly cheap but if you have access to a fuel pump pressure tester, you might check pressure first.
also for future referance, your truck does not have a carburetor if it is stock. 98s were EFI, non throttle body injection, meaning MPFI.
Old 09-01-2009, 02:08 PM   #5
look at me, 3 minutes late and a dollar short.
Old 09-01-2009, 04:25 PM   #6
Will check this out..
Bradrhale; Thank you too!! I will have these things checked and keep them in mind for the future. Didnt even know it didnt have a carb..duh!!!!
Old 09-08-2009, 07:08 AM   #7
Had the truck in(being checked) since the first post,almost a week. The man has run it, tested it,has a pressure gauge on it. Hwy speeds,in town,and it still hesitates and looses power at certians times.Talked about sensors,fuel pump,dirty injectors,etc..he cant seem to find the problem..guess its time for another truck. Only has 123,000 on it..
Old 09-08-2009, 09:43 AM   #8
checked timing on it yet?? popping through the throttle body is a sure sign of timing problems. could be due to a junp in the timing chain or various other problems associated with such.
Old 09-08-2009, 10:29 AM   #9
BernieB's Avatar
Not for nothing but... If that shop can't find the problem after having the truck for a week I'd find a different shop.
As Brad has said, popping back through the intake is almost always caused by a problem with timing, and timing issues are fairly straightforward to deal with.
Old 10-08-2009, 08:47 AM   #10
1998 Dodge Ram 1500
Thanks for all your input.I havent had the timing checked yet.I dont drive very much and it seemed to run better,then it started to "pop" again and "backfire".Still acts like its hesitating/fluttering/missing at cruising speeds. I think I will get it into another shop and have the things done that you described.
dodge 1500 problem what to buy next ?? gsxrman2007 Dodge Truck Forum 9 08-01-2009 11:05 AM
98 Dodge Ram 1500 no fire kwulkat Dodge Truck Forum 8 09-24-2008 06:48 AM
Dodge Ram 1500 Hemi Nicku812 Introductions 2 02-12-2007 08:40 AM
2003 dodge ram 1500 sb,cc marrsbarak Dodge Truck Forum 0 12-19-2006 12:45 PM
Dodge 1500-1999 TERC_TX Dodge Truck Forum 1 07-06-2006 10:24 PM
