| Ok a friend of mine has a 1976 Powerwagon that he has put a 440ci RV engine in he has an issue. The issue is the left valve cover is leaking at the rear. He thought at first it was because the engine has so much torque that it was rolling over and hitting the brake booster. He has clearanced the valve cover so it would not hit. It still leaks he has tried everything from new gaskets, RTV different covers and even the stock covers( i forgot to mention that he has the Mopar valve covers the ones with the pentastar on it) and it still leaks. Anyone come across this issue or know why or how to correct it? Thanks
| I've done a lot of work on those engines (I used to own a Winnebago that had one) and that type of leak was fairly common. The problem is that the bolts for the covers don't spread the pressure evenly, even when you use the stock spreaders. My solution was to custom make a set of spreaders out of spring steel with a slight curve to them, and a little longer than stock. This spread the clamping force out over a wider area and stopped the leak.
| | #3 | |
__________________ ENGINES PRODUCE POWER. MOTORS RECEIVE POWER.![]() https://lastroundbestround.com/Home_Page.html | |
| some thing like this.
__________________ ENGINES PRODUCE POWER. MOTORS RECEIVE POWER.![]() https://lastroundbestround.com/Home_Page.html Last edited by Crmzendrgone; 09-18-2009 at 03:11 PM. |
| | #5 | |
| Probably, could have made a lot of money!
| | #7 | |
for how to handlie slow oil leaks. And it had the beauty of simplicity too. Just duct tape an oil IV drip to the antenna. I suspect a conspiracy from Detroit to stop me. ![]() | |
| | #8 | |
| Truck bed covers | bubbatrucklover | Chevy Truck Forum | 6 | 08-16-2009 12:34 PM |
| Tonneau Covers | GMC-Truck-Guy | GMC Truck Forum | 16 | 09-13-2008 06:41 AM |
| bed covers | das5293 | Ford Truck Forum | 5 | 12-07-2007 05:51 AM |
| 4 Sale! Truck Box,Grill,Valve Covers,Tail Gate,bumper, | Jenna | Chevy Truck Forum | 1 | 10-08-2006 06:58 PM |
| Car/Truck Covers | 390FE | General Truck Forum | 10 | 10-26-2005 08:52 PM |
