Old 10-03-2009, 12:23 AM   #1
hls30 is on a distinguished road
intake gasket 360 magnum
Is there a better gasket set for the common air leak caused by the intake-valley pan gasket failing. I have had it done twice am I am at 90,000 miles. I understand you should change out the bolts when you do this and I made sure they were done the 2nd time it was done. That was about 20,000 miles ago.
It has the typical pinging at part throttle under load even when the truck is empty and a very slight hill. It has now started idling erratic like a vacuum leak. I have sprayed brake cleaner all around the intake manifold and around the vacuum lines and it does not change the erratic idle. It does it more when it is warming up but mostly will idle fine once it is fully warm. During warm up if I hold the throttle just lightly I can get into a lean surge condition as as I apply a little more throttle you can hear what appears to be another or two cylinders kicking in. During this warm up time if I put it in neutral and hold just above idle it will surge back and forth between 2500 rpm and 800 rpm. The idle speed motor seems to be operating as I shift in neutral at red lights it will try to compensate and again when I shift it back into drive. The check engine comes on sometimes but not always. I know an intake leak could cause oxygen sensor fault codes. I gues maybe I should have injector pattern checked while the intake is off. I will have the codes read as well.
Is there anything else that I may be overlooking that could cause this type of type of symptoms.
I would appreciate any help.
Allan
hls30 is offline   Reply With Quote
Old 10-03-2009, 01:36 AM   #2
BernieB's Avatar
Edelbrock makes a good gasket set for that intake. Much better than Fel-Pro IMHO. And I agree, it sounds like a vacuum leak you're dealing with, but before you go tearing it down and doing the gaskets you should locate the leak. Might not be the gaskets this time.
Old 10-03-2009, 11:04 AM   #3
Thanks, good idea I will start pinching some hoses including pvc valve, brake booster, evap and even the ac- heater flap diaphragms and hopefully see a leak. The reason I thought it was the gasket is the way the problem at idle goes away once the engine is fully warm but it still pings like crazy with a very slight load even when the truck is completely empty.
Old 10-03-2009, 12:12 PM   #4
BernieB's Avatar
Pinging can have other causes besides a vacuum leak.
Old 10-03-2009, 04:10 PM   #5
From what I understand there is no knock sensor. I have actuated the egr valve to see if if the pinging goes away under load and it won't. The timing is fixed and I understand the distributor does only spark distribution and the timing is crank sensor controlled . I did change out the cat last year but not because it was restricted. The pinging stays the same no matter if I use 91 octane or 87 octane. The pinging is even under very slight load like 1/8 throttle opening and goes away once you reach a constant speed. I would think that if the pinging was timing induced it would be better with the 91 octane versus the 87 octane specially at such small throttle openings.
I don't know maybe I am overlooking something. I am sure it is, it is always something that is being overlooked.
thanks
Old 10-13-2009, 12:53 PM   #6
jimbo543 has a spectacular aura aboutjimbo543 has a spectacular aura about
dealer has a metal plenum gsk, try flushing/cleaning injectors and running top engine cleaner through engine. use fuel injector cleaner in the tank.
jimbo543 is offline   Reply With Quote
could it just be the intake gasket jer Chevy Truck Forum 10 11-29-2008 01:21 PM
intake gasket leaking Newkidlearning5 GMC Truck Forum 15 10-05-2008 06:06 PM
83 gmc intake manifold gasket joeydeherrera54 GMC Truck Forum 20 02-26-2008 05:34 AM
Intake Manifold gasket dbujnak Chevy Truck Forum 13 02-24-2008 08:27 PM
2003 gmc intake gasket? 2003bruce GMC Truck Forum 3 12-15-2007 06:33 PM
