| Junior Member Join Date: Apr 2006
| I have 1979 Dodge Adventurer the firing order on the truck and the chilton book disagree. The distributor seems to be backwards and the firing order is 1,2,4,3,6,5,7,8 So what is up? Any ideas? |
| Full Member Join Date: Dec 2005
| What size engine is it? Is it the stock intake manifold or did someone change it out. Is the engine stock. Does it run? More info is needed. Make sure the rotation of the distributor corresponds with the firing order. I have a few books at home that I could cross-refrence to varify.
__________________ 1978 dodge adventurer 1 ton dually crew cab. 440 4wd. 4" lift. |
| Senior Member Join Date: Jul 2006 Location: Tulsa, stationed at Ft. Sill, OK
| More info is needed for this one, and this thread is so old now it maybe a mute point. Most MOPAR V-8s fire with 1,8,4,3,6,5,7,2. If it is the original manifold the firing order will be on it. Does it run? Is the distributor in the front of the block or back next to the firewall? |
| firing order1995 silverado help help>>>>>> | scmamatrucker | Chevy Truck Forum | 9 | 03-12-2006 08:47 PM |
| What are your experiences with the 2002-2005 Dodge Ram Trucks? | Info Seeker | Dodge Truck Forum | 2 | 01-14-2006 01:23 AM |
| 2000 Dakota V6 Firing Order | seadog | Dodge Truck Forum | 0 | 01-02-2006 04:56 PM |
| I need to know firing order for '95 sierra | gmcer | GMC Truck Forum | 4 | 04-05-2005 07:08 AM |
