| Junior Member Join Date: May 2005
| brake light problem i have a 99 dodge ram quad cab 4x4 with 5.2 automatic. the abs light came on along with the brake light, there seems to be no problem. it has happened before and always went out. i even pulled the 10 amp fuse by drivers door brake light went out not abs so i pulled the 40 amp fuse from under the hood, but light still stayed on any help? also my speedometer started acting up today it will stay on 0 mph till iguess i hit about 20 mph then works fine, bit after i slow down to stop after it hits 20 mph it goes straight to 0 mph even when i am moving under 20 mph any help on that also? thanks! mister one thing after another!! |
| sounds like you got a wiring nightmare. |
| thanks i was thinking it was a sensor also, just average mechanic trying to get other opinions. also i have owned this truck since it was new have always maintained it. so i know it has not been rigged up. thanks again |
| Junior Member Join Date: Jun 2006
| There's a speed sensor for the ABS system located on your rear differential that reads a "tone ring" that is on the ring gear assembly. Sounds like the sensor is bad or the electrical connection is faulty, probably a bad sensor tho. Your symptoms you describe indicate that the sensor is not functioning anymore.About $25 at the stealership. |
| Full Member Join Date: Sep 2006
| Check it for codes? |
| Full Member Join Date: Jul 2006
| brake and abs light proble try purging the front brakes and disconnecting the pos side of the battery then reconnecting it. i would first. |
| 2000 ford f350 door ajar light problem | be4969 | Ford Truck Forum | 3 | 05-29-2006 08:07 AM |
| Dodge truck brake problem | BlakRam | Dodge Truck Forum | 3 | 04-02-2006 03:27 PM |
| problem with the Door open light | BTAY | Ford Truck Forum | 4 | 03-30-2006 09:27 AM |
| 1997 chevy tahoe gage light problem | bajaboy | Chevy Truck Forum | 5 | 03-23-2006 07:58 AM |
| Check Engine light and overdrive light on | chief | Introductions | 0 | 02-05-2006 07:12 AM |
