| Junior Member Join Date: May 2005
| trans slip? i have a 99 quad cab with automatic overdrive, this question is gonna seem crazy but here goes, i am getting a slip or something is taking it out of gear when i turn to the left sometimes to the right but never straight it seem kinda more like slipping out of gear if a push down on gear shifter it will go back in, i am not hitting the gear shift to make it come out, is there a valve or switch or something going bad? told you it was weird, thanks |
| have you checked the linkage under the truck? maybe something is catching in the steering column.
| Full Member Join Date: Oct 2006 Location: south carolina
| trans slip? I'm with mudseeker on this one.Check the linkages. P.s.-Is this a column shifter? |
| yes this is a column shift, thanks |
| 1989 k2500 trans leak | threearmsinjune | Chevy Truck Forum | 2 | 11-03-2007 09:54 PM |
| Dodge Auto Trans Slipping? | markmassett | Dodge Truck Forum | 6 | 10-02-2006 12:45 AM |
| 10 bolt rear diff with 3:73 limited slip carrier | chevyguy | Truck Classifieds | 13 | 06-16-2006 10:21 PM |
| 06 1500 gmc trans problems | wvtommy | GMC Truck Forum | 1 | 02-28-2006 06:11 PM |
| Trans & t Case | elkzzilla | Chevy Truck Forum | 1 | 12-04-2004 09:25 PM |
