| Full Member Join Date: Jul 2006
| cold Ram Hello everyone! i have a 97 Dodge Ram and the heater dosen't seem to work like it should, water temp is good, just flushed the cooling system and checked the blower wich works good. funny part is the air coming out of the vents gets warmer when i rev and hold the engine speed at 2000 rpm, let it drop to idle gets cooler. any suggestions? |
| | #2 | |
__________________ '85 Oldsmobile 442 '93 Chevy 2WD C1500 350 Silverado Extended Cab Shortbed '95 Chevy 4WD K2500 454 Silverado Extended Cab Long Bed | |
| Full Member Join Date: Sep 2006 Location: Manitoba
| heater problems Did you reverse flush the heater core. This means to hook up a clean water supply and run water in the reverse direction through the heater core. Garden hose works best. |
| | #4 | |
| yes when i flushed the system not only did i do an entire system flush i then flushed the heater core itself, both ways multiple times blowing it out with compressed air after each rinse. how do you guys purge the air out of the system? |
| | #6 | |
| Full Member Join Date: Jan 2007 Location: minnesota
| ive fixed a dozen of these things all with the same problem, its a vac leak somewhere usually on the transfer case, let me guess when u drive down the road with the heater on pannel it blows heat until u get on it and then it automatically goes to the defrost vents. and your 4x4 "light" may or may not be doung the same thing. |
| "06" cold battery warning | sully231 | Dodge Truck Forum | 12 | 09-17-2006 06:44 PM |
| What is a good Cold Air Intake? | rickards | Chevy Truck Forum | 12 | 12-07-2005 06:01 PM |
| cold weather rough idle | 01chevsilv | Chevy Truck Forum | 2 | 12-07-2005 05:07 PM |
| Driving cold | Moostang | General Truck Forum | 8 | 10-13-2005 06:43 PM |
| Family Spends Cold Night In Snowbound Truck (KOIN News 6) | trucknews | Truck News (headlines) | 0 | 01-04-2005 07:30 PM |
