Old 12-15-2006, 03:27 PM   #1
Catstorman is on a distinguished road
Hydraulic Clutch Problems
Hi Guys, I have a 1995 Dodge 2500, Cummins Turbo that has suddenly developed a leak in the hgydraulic line that operates the hydraulic clutch. At idle, the leak pumps out about a quart of fluid in 10 minutes. It appears that the line rubbed against the fender housing and rubbed a hole. The dealer is telling me that this is a dealer only item, a closed system, available only from them. The local hydraulic man says that he cannot repair the line because it is a hard plastic composition and conpressions will not work. The dealer wants an obscene dollar for the entire assembly.....HELP ???
Catstorman is offline   Reply With Quote
Old 12-16-2006, 03:16 AM   #2
Bonnor is on a distinguished road
maybe try a wrecker?
Bonnor is offline   Reply With Quote
Old 01-05-2007, 11:11 AM   #3
JACKER1 is on a distinguished road
Catstorman,
Have you looked into possibly getting one from a salvage yard? I just had to replace my radio and got it for 25.00 at a salvage yard.
JACKER1 is offline   Reply With Quote
Old 01-05-2007, 01:55 PM   #4
03chevy's Avatar
like bonnor and jacker1 said go to the junk yard and get one. then after you get one heres a little trick to do to the new one. after you install the new one look where the old one was rubbing get a rubber hose and cut it the lengh you need to cover that spot and then cut it down the middle to rap it around you new hose so that it can not rub a hole in your new hose. and zippy tie it to your hose so it doesn't move. i have done that quit a few times to save me from haveing to redo it all over again.
1987 Full Size Hyd Clutch Problem wojeepster Chevy Truck Forum 6 08-14-2006 08:47 PM
4 Wheel Drive Problems 92BlueZ71 Chevy Truck Forum 7 03-12-2006 03:22 PM
Help on Mazda Truck Clutch stina3246 Mazda Truck Forum 11 03-11-2006 10:40 AM
clutch bleeding 72'CaminoKid Ford Truck Forum 6 11-28-2005 10:42 PM
98 electric problems 98Z71 Chevy Truck Forum 4 08-20-2005 07:39 PM
