| Hi All I have a charging problem? Computer Reads 13.8 to 14.1 volts on the scanner But at the battery an back of altenator voltage reads 12.6 . I check grounds cables an have ign feed to alt field as well as computer ground at field any help would be appreciate Thanks Last edited by gildually; 01-10-2007 at 10:22 AM. |
| Senior Member Join Date: Mar 2005 Location: ontario, canada
| charging i had some low voltage a few weeks ago and you need to remove both bat cables and make sure they are clean also at the frame and starter also check if there is a big draw check with amp meter ........pete
__________________ I am gm all the way ....... black 98 Z71 3 door short box 5.7 |
| Thanks Pete went down that road already no draws cables are clean as are all grounds. Waiting on a computer to get here as that controls the charge rate. Thanks Joe |
| hi all Put a remanufacted computer in solved all athe charging problems . It runs better than ever. |
| Glad to see it's running better!
| 1997 Chevy PU problem leak into heater fan | annerupert | Chevy Truck Forum | 4 | 06-04-2007 11:38 AM |
| Hello All\help..94 Diesel Stalling Problem | collision guy | Introductions | 3 | 08-01-2006 07:16 AM |
| 1997 Dodge Ram Extended Cab Slt*nice | mrhaney | Truck Classifieds | 1 | 07-13-2006 11:23 AM |
| 1997 chevy tahoe gage light problem | bajaboy | Chevy Truck Forum | 5 | 03-23-2006 08:58 AM |
| Diesel problem | jgn | Dodge Truck Forum | 2 | 06-01-2005 05:22 PM |
