Old 01-22-2007, 02:59 PM   #1 (permalink)
Jake is on a distinguished road
Doge Ram shift problem
I have a 1995 Dodge Ram 2500 series pickup. 4x4. Auto trans.
86k miles.
Shifting problem: Code #34
Symptoms:
Usually shifts from 1st to 2nd o.k. rpm can reach 3500 before it will shift into 3rd. 4th and o.d. shift normally.(this is an intermittent problem). Sometimes will not shift out of first gear until rpm's are very high. If I use the accelerator gently, it will shift correctly most of the time. If I press down hard on the accelerator, such as shifting into passing gear, it seems to start the shifting problems I just explained. Next time I start the truck it will shift through all gears perfectly. Code #34 still lit. I don't think it's the transmission that's the problem. I get no slippage and when operating normally, it shifts perfectly. Could it be a sensor?
Thanks;
Jake...
I changed the transmission filter and fluid. I also replaced the speed control on the transmission
Jake is offline   Reply With Quote
Old 02-08-2007, 10:18 AM   #2 (permalink)
DEP
DEP is on a distinguished road
I`am having the same problem,with my dodge,Does anybody know anything about this/ Sensor? I dont think its the tranny..Heck the Dodge dealer doesnt evan know.If they do there keeping quiet about it.
DEP is offline   Reply With Quote
Old 02-11-2007, 09:12 PM   #3 (permalink)
Larry O'Daniel's Avatar
Larry O'Daniel is on a distinguished road
I was told by a transmission shot that my 96 RAM transmission was essentially a 727 with electronic sensors added. IF this were an older MOPAR I would quickly say you have a dirty valve body and possibly an almost clogged filter. Yes you changed the fluid, but how long ago, and how long before this time did you change it. Was it shifting this way before the change? If you have never changed the fluid/filter than you have possibly "cleaned" the trans and redeposited all of the "stuff" on the filter and valve body when you just changed it. The sensors certainly throw their own brand of problems which is obvious since the dealer doesn't want to commit to. You did not mention whether the truck didn't shift correctly when cold and worked fine when hot, or does temperature not make a difference.
Larry O'Daniel is offline   Reply With Quote
Old 03-01-2007, 12:08 PM   #4 (permalink)
Tucker Oil's Avatar
Tucker Oil is on a distinguished road
every thing that I can find says that the coed #34 is the speed control vacuum or vent solenoid. but there was different symptomsso that just means that you need to check any vacuum lines and electrical conection conections.
2000 dodge 3500 w/cummins turbo diesel, suncaost tranny, hrvp44, 110 hp injectors, AFE intake, mbrp 5", and Amsoil through out!! www.lubedealer.com/btucker
mods thanks to www.dieselnut.com
Tucker Oil is offline   Reply With Quote
Old 06-27-2008, 09:10 PM   #5 (permalink)
willie vigil is on a distinguished road
try changing out the tranmission relay at the power distribution box or check shift solenoids on valve body . hope it works
willie vigil is offline   Reply With Quote
E4od no shift ragtagf150 Ford Truck Forum 13 03-05-2007 08:06 PM
front brake problem 03 Ford f250 hdkidd Ford Truck Forum 2 12-13-2006 08:17 AM
'99 F250 SD with strange problem ColoQuarterH Ford Truck Forum 4 08-20-2006 09:37 AM
shift problem beno Introductions 3 07-18-2006 07:38 AM
1997 chevy tahoe gage light problem bajaboy Chevy Truck Forum 5 03-23-2006 07:58 AM
