| Junior Member Join Date: Jan 2007 Location: Full Time RV'er
| Hi guys. I have a 1998 Dodge Ram 3500, 5.9 Diesel. I am istalling a boost guage and was wonder were is the best spot to hook up the line. At the turbo wastegate hose on the manifold? If the manifold were at?? I can't find any ports. Thanks if you can help |
| 98 - 2000 24valve Cummins For this insrtallation, first you must purchase a 3/4" to 1/8" reducer. Then locate the 3/4" pipe plug located on the intake between the fuel filter, and the firewall on the back side if the engine, it has a 1/2" square in the center, and can be reached with a ratchet, and an extension. Install the reducer, then install the boost gauge fittings, and line per manufacturers directions, and you are done! Good luck, and use some type of thread sealer to prevent leaks. |
| Boost | project88 | Ford Truck Forum | 5 | 06-15-2006 12:54 PM |
| 01 Sierra with a jumpy fuel guage | wernettejr | GMC Truck Forum | 5 | 05-03-2006 03:40 PM |
| 4x4 and fuel guage problems? | nate3436 | Chevy Truck Forum | 1 | 01-31-2006 05:28 PM |
| temp guage | gb&sb | Chevy Truck Forum | 0 | 12-02-2005 05:07 PM |
| Remade truck, drills boost water safety (Poughkeepsie Journal) | trucknews | Truck News (headlines) | 0 | 02-19-2005 05:30 PM |
