Old 04-03-2007, 08:31 PM   #1
Page is on a distinguished road
Carb question
Hi all, I'm wanting to replace my TB with a Holey or Edlebrock carb. Can I use this intake, what about the wires to the TPS, will this affect the brain box in some way? Thanks in advance
`91 D-150 5.2L
3spd w/Low 350 rear
Page is offline   Reply With Quote
Old 04-03-2007, 09:23 PM   #2
junior3382's Avatar
Welcome to the site....
I would think that if you are reverting from fuel injected to carburated that you will run into some problems. More than likely you can't use the intake, especially if you are looking for more fuel and air mix and for performance. also, not having the injector sensors connected, like the TPS or MAP, will affect your cmp. Carbs don't generally use these parts. But I am curious, why? What are you looking to accomplish? Is there a problem with the throttle body? Maybe answers to these questions could shed some light on what to look for, and give some of the experts here some more info to work with....lol.
Old 04-04-2007, 06:11 AM   #3
i agree, why would you want to do away with the TBI?? you can get higher CFM units just like carbs. the tbi will give you many times better fuel atomization than that carb will ever give you. dont worry about it affeting your computer. you will always have a service engine soon light if you revert to a carb. your MAF and o2 sensors will be useless and you wont have a need for a TPS. if this is going on your d150, you should not have a problem with the tranny as they still used a tv cable instead of wires. i would hold on to the TBI though.
Old 04-08-2007, 02:58 PM   #4
The carb swap was a suggestion as a uick fix instead of lots of trial & error & $$ on various sensors.
The truck stalls @ idle, runs rough, OK, rough, OK. Did the plugs, wires, cap, rotor, TPS, all with little to no change
Old 04-09-2007, 05:50 AM   #5
does you truck bring up any codes at all?? there are really not that many sensors left on that old of model. a carb swap might be an excellent suggestion but for the cost of a new carb, you can buy nearly all the sensors for that truck plus an oil change.
Old 04-24-2007, 11:31 AM   #6
Tucker Oil's Avatar
Tucker Oil is on a distinguished road
if you were to convert to a carb. you would not be able to smog your vehicle any more one because of the check engine light and to because the sensors work together to with ecm and the tb to keep it smogable.
2000 dodge 3500 w/cummins turbo diesel, suncaost tranny, hrvp44, 110 hp injectors, AFE intake, mbrp 5", and Amsoil through out!! www.lubedealer.com/btucker
mods thanks to www.dieselnut.com
Tucker Oil is offline   Reply With Quote
carb issues geoff Mazda Truck Forum 0 03-21-2007 11:44 AM
seems like a newbie question but i am flustered dixieduck Nissan Truck Forum 5 03-13-2007 12:22 PM
turbo tbi question flyinhillbilly Chevy Truck Forum 8 01-13-2007 07:42 PM
Carb not squirting gas Outlawsnut Toyota Truck Forum 11 09-06-2006 10:07 AM
Carb Info? great_beer_man General Truck Forum 14 05-30-2006 10:14 AM
