Old 04-04-2007, 03:03 AM   #1
danxtc is on a distinguished road
Question Belt Squeal
My 96 Dodge has belt squeal. I've tried 3 different brand names of belt and they all squeal more or less than the others. I've refaced the pulley surfaces (mechanic advice) and it made no difference.
I checked all idlers and the A/C, water pump, PS motor & Alt. - no noise there.
One brand only squeals when it is cool & damp - when hot : no noise.
One brand squeals all the time; but gets lower in volume when it warms up.
This only started about 6 mos. ago. I've had the truck for 11 years.
Any ideas?
Dan
West Jersey
96 Dodge 4WD
danxtc is offline   Reply With Quote
Old 04-04-2007, 05:58 AM   #2
are all these belts showing any signs of premature wear?? does it squel all the time or just when you turn the steering wheel or turn on the ac?? did you look at each pulley and make sure that there is no trash on any of them as in grease or oil??
Old 04-04-2007, 07:39 AM   #3
Have you checked the tensioner while the motor is running. A worn out tensioner even with a new belt might not be putting enough tension on the belt. Check it and see if it has alot of movement while running.
Old 04-04-2007, 01:28 PM   #4
03chevy's Avatar
i agree with mrjohnwayne the tensioner or the idler pullies will be your problem
Old 04-04-2007, 04:16 PM   #5
0425004x4's Avatar
0425004x4 is on a distinguished road
I would replace tensioner and put old one in toolbox for spare if you break down on road.
0425004x4 is offline   Reply With Quote
Old 04-05-2007, 03:31 AM   #6
Belt Squeal
The first belt only has about 3,000 miles on it (This was the 3rd belt on the truck after 160,000 miles). The other two I had tried are brand new.
(This is getting costly!)
The idler had been replaced aro. 115,000 mi. (it was sticking)
The tensioner was adjusted per the manual spec.
All belts are clean and the squeal exists as long as the engine is running (no turns required) and changes pitch with rpm till it finally goes away after warming-up.
Dan
West Jersey
96 Dodge 4WD
Old 04-05-2007, 05:41 AM   #7
can you pinpoint the squel a little bit to kinda give us a hint as to what the problem might be??
fan belt 1derf Chevy Truck Forum 2 03-26-2007 07:30 PM
serpentine belt question 89 k2500 threearmsinjune Chevy Truck Forum 1 11-04-2006 04:18 PM
serpentine belt diagram for 1993 4.3 crazyhorse357 Chevy Truck Forum 7 10-04-2006 05:29 PM
Timing Belt will4831 GMC Truck Forum 11 03-28-2006 12:17 AM
serpentine belt scottie Chevy Truck Forum 3 01-25-2006 12:51 PM
