| Junior Member Join Date: Apr 2007
| No Bus I have a 2000 Dodge 2500 diesel,when you turn on the ignition none of the gages,tach,or speedometer work and NO BUS appears on the mileage gage.I have checked all the fuses. Anyone had this problem and know what is wrong? |
| Sorry cant help you on this one.
| Thanks anyway Johnwayne. It did this about a year ago, then before I could figure out what was wrong it cleared itself up. Then yesterday the same thing again. None of the gages work, but it starts runs good ,air conditioner, turn signals, radio all work, just no gages, tach, or speedometer. |
| I do not know first hand, but I do recall the dash having some sort of memory, and if you had any type of battery issues just prior to these symtoms, they might be related. The dealer says to disconnect the battery for a minute, or two, and re-connect it. The gauges should work again. If that fails the dealer will have to reprogram the PCM and runs about $50.00 (U.S.) |
| I disconnected both batterys for about 5 minutes connected them up again still the same problem. Guess I am going to have to take it to the shop. |
