| 95 dodge diesel Electrical problems Truck starts fine, but does not act like the batteries are being charged. the volt gauge reads in the low normal range . before it always was close to 14. Now it's runs below that. Yesterday the Check engine light came on so i figured that the voltage was low in the system. i put the charger on it for a couple of hours . the battries where low. I replaced the altinator tonight. and it look like there is still a problem. i also found that the A/C cluch will not energize . blower works. wipers work. and all of the lights work. I have looked at all of the wires and checked the fuses. everything looks ok Anyone have any ideas |
| When was the last time you used the AC. Could be low on freon causing the clutch to not engage. might want to have your batteries load tested. A bad alternator can ruin good batteries.
| I have figured out that it's most likely the PCM. I have a apointment at the dealer to check it out instead of throwing parts at it. |
| Good deal man.
| 98 dodge dekota ..problems with start up | bradonlaptop | Dodge Truck Forum | 1 | 07-01-2007 07:36 PM |
| 97 Dodge 1500 4 X 4 electrical problems | Phil Herr | Dodge Truck Forum | 3 | 02-11-2007 09:58 PM |
| Electrical problems | wileec | Ford Truck Forum | 11 | 01-05-2007 03:03 PM |
| 2000 dodge truck problems | treynolds | Dodge Truck Forum | 2 | 11-25-2006 08:44 PM |
| Sorry, newbie needs help big time 89 Dodge D350 Problems | TheStoneDoor | Dodge Truck Forum | 24 | 06-16-2006 01:13 PM |
