Old 05-18-2007, 06:43 PM   #1
BowtechAndy is on a distinguished road
air sucking noise
99 ram 4X4 with a 5.9L V8. Its making a vacuum leak noise but nothing is leaking. Its not all the time either. any help would be great.
also, I am getting average of 13 miles to the gallon. I am lifting and going with bigger tires. Would you suggest reprogramming the computer with a hypertech? Is it worth the $350?
thanks
andy
BowtechAndy is offline   Reply With Quote
Old 05-18-2007, 07:05 PM   #2
Welcome to the site.
If you have a vacuum leak sound, then it has to be leaking. How do you know it is not?
As for the reprogram, what are you hoping to achieve by reprogramming?
Since you mentioned gas mileage, I am confident that after you increase the tire diameter, and increase rolling resistance, a computer re flash, or reprogram will not provide any better mileage. You might get back to a similar mileage if you change the gears but don't expect magic from a programmer.
Old 05-18-2007, 09:20 PM   #3
Because I have traced every line and can't find any leaks. The only one it might be is the big one right under the air breather cause its kinda loose fitting.
As for tires I will be using 285/75/16 which is basically a 33. After reprogramming to the larger sized tire it should still improve over what I am getting now. I hope!!!
Old 05-18-2007, 09:35 PM   #4
what did you do other than visually inspect he lines to verify they were not leaking? Have you tried introducing a chemical, either liquid, or gas to verify no leaks? Bet if you run some propane around with a small hose, you will find the leak. Works every time.
Old 05-18-2007, 09:49 PM   #5
how is that done?
Old 05-18-2007, 10:06 PM   #6
Some guys use something like brake cleaner, or carb cleaner, to detect vacuum leaks. If you spray a little around a suspected area, the engine rpm will change. Once a change in idle is detected, you have found your vacuum leak.
The other method is to use a gas like propane, or similar gas, (combustable gas, inert gases will not work). I use the gas method because with the help of a smalll wand that I made, I can concentrate the gas on a smaller more acute area. The results are the same.
The gas method is a little safer (more safe?) than the carb cleaner. Carb cleaner has been known to catch on fire every now and then if sprayed on a dist cap, coil or something like that. Although it will also tell you if you have a spark plug wire that is arching somewhere, it is still a little dangerous to say the least.
Old 05-18-2007, 10:10 PM   #7
so just squirt a little on a hose to see if it leaks? Thats sounds waaaaay to simple. Can you think of a harder way!!!!!!
Old 05-18-2007, 10:56 PM   #8
Spray on one hose, and listen for the engine rpm to change. The change in rpm will indicate a leak that is otherwise invisible to the eye.
But, if you want it a little more difficult, leave the hood closed, (LOL) that should make things a little more difficult for you...........
Old 05-19-2007, 05:22 AM   #9
hahaha good one!!!!
Old 05-19-2007, 11:20 AM   #10
tried using the spray on all the lines except the one under tha air breather just because I couldn't reach it. Noting changed so I am thinking that its either that hose or its just a noise that the intake makes.
Gonna try something else on a day its not raining.
thanks
andy
1994 c1500 - clicking noise from heater Chris Chevy Truck Forum 19 02-11-2009 07:10 AM
Manual Trans. Noise JACKER1 Dodge Truck Forum 4 01-05-2007 01:15 PM
brake noise under the dash jktuck GMC Truck Forum 8 10-05-2006 08:59 PM
A/C Noise - 2001 Chevy Tahoe sandman3175 Chevy Truck Forum 4 08-16-2006 07:34 PM
Bothersome noise StrictlyGMC GMC Truck Forum 7 05-17-2005 03:47 PM
