| | #11 |
| Senior Member Join Date: May 2007 Location: Maine
| fluid and filter was changed a month or so again. he said the pan was fairly clean as was the filter. fluid had good color but a little looser than new fluid. |
| | #12 |
| Senior Member Join Date: Jun 2007 Location: Somewhere, PA
| (Scratches head) It might be the Throttle valve (TV) cable. It might be misadjusted or damaged. Jim "the greasemonkey"
| | #13 |
| he said the tranny, pan and everything else under there was clean as a whistle. |
| | #14 |
| I'll have to do some reading in my shop manuals, I'll try and get an answer to you soon. Jim "the greasemonkey"
| | #15 |
| | #16 |
| ![]() The transmission end TV cable assembly mounts to the transmission case by a single 6MM bolt. A rubber sleeve type seal placed between the TV cable housing and the case hole prevents fluid from leaking out of the transmission. Check to see if there is any slack or if the cable is too tight. Also check to see if the cable assembly is damaged. Jim "the greasemonkey"
| | #17 |
| there is very slight slack up where it mounts to the throttle control link. |
| | #18 |
| I would take it to the Chrysler dealership and have them take a look at it. I really can't say beacause I can't see the linkage. Jim "the greasemonkey"
| | #19 |
| come on now, a dealer? You know that they are gonna wanna change it and it will only cost a thousand or so |
| | #20 |
| I dont know if your buddys truck is still under warranty or not. That part is covered by the warranty, so it wouldnt cost a thing to get it fixed.
| Carb, Timing or Transmission Problem? | marksspot | GMC Truck Forum | 18 | 06-11-2007 11:20 AM |
| transmission problem 83 gmc | joeydeherrera54 | GMC Truck Forum | 2 | 03-20-2007 09:27 PM |
| E4od no shift | ragtagf150 | Ford Truck Forum | 13 | 03-05-2007 09:06 PM |
| Transmission Problem | z71chevy1996 | Chevy Truck Forum | 0 | 12-23-2006 04:05 PM |
| Clutch or Transmission problem?? | nickelbn1 | Ford Truck Forum | 2 | 07-19-2006 04:14 PM |
