| dakota just quits anytime . on restart ,if check engine light comes on it will start. if light doesnt come on you can crank but wont start. any ideas.? have changed crank senser |
| I had an explorer in the shop once with symptoms similar to that, and it turned out to be the ECM. |
| Senior Member Join Date: Jun 2007 Location: Somewhere, PA
| You may have one of the following problems: 1. Broken, loose or disconnected wires at the ignition coil or a short in the ignition system. 2. Faulty distributor pick-up coil or ignition module. Jim "the greasemonkey"
| im thinking it may be PCM (very expensive, hope its not this) or maybe something easy and cheap as a fuel filter(hope for this one). it definitly sounds like a fuel problem to me
| i had that same thing happen to me in a 87 dodge d150. i drained the tank and cleaned it up and never happened again. out of 20 gallons of gas, i pulled out almost gallon of water and enough rust to sink the titanic. no pun intended. |
| Truck will start but wont stay running | PickUpGirl787 | Chevy Truck Forum | 6 | 12-29-2006 11:08 AM |
| S10 Intermittent "overnight" no start continues ,need help from electrical Guru | STRAYDOG | Chevy Truck Forum | 11 | 11-09-2006 03:59 PM |
