Old 07-24-2007, 03:08 PM   #1
bstewar77 is on a distinguished road
4wd not engaging...Please help
I have a 98 dodge ram 1500 4x4 with a 7' lift, 36' swampers. Last weekend was a car show and I entered the tug o war contest. I did ok for a while, tied one guy beat another one and the last one I was pulling and heard a snap. The 4wd stopped working and of course I lost. Drove home fine I guess because it is the front that broke. I can put it in 4wd and the driveshaft spins as it should but that is about it, its like its not in 4wd because the front tires do not spin. But there is no grinding noise or anything when turning it. Putting it in 4wd pretty much doesnt do anything with the front tires anymore. Any ideas? At this point 4wd is not a huge deal for me, I hardly use it. I mainly use this truck to pull my boat back and fourth from the lake so as long as I am able to do that I'm good. Just would like to know what it may be.
Any help would be great!
bstewar77 is offline   Reply With Quote
Old 07-24-2007, 03:23 PM   #2
i bet you turned your ring and pinion into shrapnel. but i could be wrong.
i'd rather be hunting
Old 07-24-2007, 03:27 PM   #3
Ford4x4Chik27's Avatar
Might have blew your hubs...
Old 07-24-2007, 03:56 PM   #4
Is it still ok to drive in regular 2wd? The front driveshaft does not spin so it should be ok right?
Old 07-24-2007, 08:56 PM   #5
i would be cautious about that. those hubs and CV axles are still rotating when the truck is moving even though the drive shaft is not. if there is something broke in there it could bind up and cause your front end to lock up while driving, thats just a worse case scenario though.
Old 07-24-2007, 09:08 PM   #6
Thats what I was afraid of. I guess before I drive it I could open up the front diff and see what falls out. Opening that up I should see if it were the ring and pinion, correct. What about the front axle actuator shift fork thing, could that just have broken? I guess I will just have to open up the diff and look.
Old 07-24-2007, 09:13 PM   #7
not sure on the actuator, but when you crack it open have a buddy spin one tire at a time and see if everything spins freely. haven't worked on a dodge front end, so i'm basing my opinion on chevys front end.
Old 07-24-2007, 09:15 PM   #8
Sounds good, thanks for your help. Sounds like a weekend job for me.
Old 07-24-2007, 10:55 PM   #9
Opening the thing up will tell you everything you need to know. Chances are you broke an axle shaft (like where the disconnect is) or simply a short shaft. I believe even the 1500's have a live front axle with a disconnect and does not have locking hubs.
With that front axle disconnect it will be very difficult to determine whether or not it is a the diff, or the axle.
Remove the cover and look for the carnage. Either way, no matter what broke, it will require the removal of the axles to fix. The answer will be under the cover.
If it is broken in the axle and not in the diff, you will have to turn the front drive shaft, and see which axles rotate tires at the same rate as the diff.
tough to check with an axle disconnect, but can be done with the help of a buddy.
Old 07-25-2007, 10:35 AM   #10
Wouldn't he hear something if it was a busted shaft??
04 colorado 4x4 engaging problem jefwill GMC Truck Forum 1 05-26-2006 05:30 AM
Please Help!!! Problems engaging 4WD sierra 4x4 GMC Truck Forum 8 10-09-2005 11:27 PM
