Old 07-31-2007, 09:27 PM   #1
evenlope is on a distinguished road
engine throwing oil out dip stick
My husbands 1979 Ford F350 one ton truck with a 460 engine is throwing oil out the dip stick terribly. The entire engine is coated in oil. He has checked the PVC valve and it has suction when he disconnects it. Do you have any ideas for him? It was his late fathers truck and he would be heartbroken if the engine went.
Thank you for any help!
evenlope is offline   Reply With Quote
Old 07-31-2007, 10:11 PM   #2
Welcome to the site.
Too bad about the truck, but lets see if we can shed some light on it. MAybe it is not that bad
We should first starrt by asking what is different between before and now? You checked the PCV, but that is only half of it. What is the condition of the vent on the oil fill cap on the other side of the engine? How is the original air cleaner where the hose attached to the cap? Is the hose still attached? IS the originall air filter closed element system still on the truck?
Are you absolutely positive that the PCV is not partially stuck?
Any amount of air flow that is disturbed may cause this problem. It is pretty common with the 460.
Old 08-01-2007, 06:24 AM   #3
Moostang's Avatar
I agree with 75k30 to check the PCV and check to see that the valve cover is venting properly. If those are all fine then it could be the rings going. In that case I would do a compression check on all of your cylinders.
Old 08-01-2007, 10:49 AM   #4
Ford4x4Chik27's Avatar
Ugh.... blow by. I have that on my ford. But I don't really worry bout it cuz I'm replacing the motor anyway... I hope you get/got it figured out!
Old 08-01-2007, 10:55 AM   #5
peterbilt's Avatar
peterbilt is a jewel in the roughpeterbilt is a jewel in the roughpeterbilt is a jewel in the rough
flush the engine with kerosine, mite have a porthole clogged. change oil filter after you do that.
~Eric~
ɹǝʌo ǝɯ lloɹ 'sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
peterbilt is offline   Reply With Quote
Old 08-01-2007, 11:08 AM   #6
scottie's Avatar
might as well replace the PCV (like $3) and get your hands on a vacuum gauge and see what your gettin
87 Suburban engine Swap BuddyRo GMC Truck Forum 6 03-29-2007 08:12 PM
How best to remove 1972 Chevy 4x4 engine? rstricklin Chevy Truck Forum 3 08-27-2006 05:36 AM
WTB 3.0 v6 for a 92runner jvmin Truck Classifieds 15 07-18-2006 06:57 AM
Carb to TBI engine swap klink70 Chevy Truck Forum 5 02-17-2006 10:54 AM
Engine Identified! Anyone know specs? klink70 Chevy Truck Forum 1 01-30-2006 10:07 PM
