Old 08-02-2007, 02:39 PM   #1
bubbas91lariat's Avatar
bubbas91lariat is an unknown quantity at this point
Question How Do I run a trailer light harness to the back of my truck?
I have a 91 f150 and when i got it from my dad, it didnt have a lighting harness on it. We are thinking of buying a new trailer and we dont want to get pulled over for not having lights. How do i run a harness wire from the fuse/relay box in the hood?
IF YOU AINT FIRST YOUR LAST!!!
bubbas91lariat is offline   Reply With Quote
Old 08-02-2007, 02:43 PM   #2
Moderator
there should be a connector for the rear tail lights at the back of the bed underneath. most parts houses sell the connector that plugs in the factory harness so there are no cut wires.
Old 08-02-2007, 02:45 PM   #3
mod-o-tator
i just spliced in to my tail lights on my GMC. actually i spent the extra 15 dollars and bought an adapter so i didn't have to cut the tail light wires under the bed.
member map add yourself
Old 08-02-2007, 05:18 PM   #4
there is a plug for trailer lights in the fuse/relay box under the hood but i cant figure out how to hook anything up to it. and i dont really know how to splice into the taillights.
Old 08-02-2007, 05:57 PM   #5
You should be able to snag a plug from a U-Haul place or any other that rents trailers.
On the back of the package is a wiring diagram.
Whatever you touch in wires on that old a truck be sure to seal or tape over, even just pulling apart plugs and replugging.
Insulation and orig sealants get brittle after a while. If you don't use extra protection, before winter is done you may have no lights on trailer and none on truck too. Moisture tends to crawl up under insulation and corode the wire invisibly. And if you're getting freezes that breaks strands too.
Old 08-02-2007, 06:21 PM   #6
Thanks. Ill see if tht wrks.
Old 08-03-2007, 08:09 AM   #7
390FE's Avatar
390FE will become famous soon enough
The plug johnwane was talking about is usually on the rear drivers side near the tail light. The wires run back the length of the truck to the rear. There is a seperate wire harness going from the end of those wires to the tail lights. The connector it a T connector with male and f-male on the top of the T and a length of wire with the 4 way flat off the bottom of the T.
Unplug and replug. No thought no wiring and a lot faster, unless the stock plug dosen't want to come unpluged.
87 Toyota 4x4 -- 72 F250 -- 68 F250 -- A Ford kah -- New to Family is 07 Ranger FX4
390FE is offline   Reply With Quote
Old 08-03-2007, 05:13 PM   #8
I found a little plug that ties into the taillights. Its shaped like a circle. Is that the one yur talkin about John?
Old 08-03-2007, 05:46 PM   #9
Moderator
If I remember it is a circular or square plug depending on year. If you can snap a picture of it it would help.
Old 08-03-2007, 05:56 PM   #10
ill see wut i can do.
Help a Student..Take a Truck Survey ClassSurvey General Truck Forum 2 12-08-2007 06:51 PM
Truck Forum BACK UP lost 1.5 days of data Admin News / Announcements 1 09-25-2006 08:58 AM
Understanding Consumer Preferences Imperative for Effective Product Positioning in the Light Truck Accessories Market (The Auto Channel) trucknews Truck News (headlines) 0 06-07-2005 09:30 AM
Car Drives Under Logging Truck Trailer (WRAL 5) trucknews Truck News (headlines) 0 02-09-2005 07:30 AM
Jury Selection Begins In Smuggling Trial 19 Immigrants Died Inside Truck Trailer (The Boston Channel) trucknews Truck News (headlines) 0 11-30-2004 07:30 PM
