| Junior Member Join Date: Aug 2007
| Question from New Kid on the Block I have a 1997 Motorhome on a Ford chassis and have lost High Speed on the heater/AC blower motor. All the other speeds work fine. Any ideas on this issue? |
| What happens when you switch to high speed, no change or shuts off?
__________________ MEOW!! |
| When switched to high the blower stops. If switched to a lower speed it runs normal. |
| its probably the blower resistor. most common cause anyways. not sure where it is located on your rig though.
| I'd check for a loose wire since the high speed essentially bypasses the resistor, either at the resistor or at switch. I'll try and find you a diagram. |
| yeah check for a wire that came off the back of the rheostat(the resistor). if that isnt visible, test for voltage to see if you have an internal failure of the rheostat
| you will have to get a new switch.
| riverman Thank you all for the help,loose wire at the switch,had to purchase new switch. GREAT HELP!!! |
| are 96 305 heads and block the same as previous years | dhashigu | Chevy Truck Forum | 9 | 08-13-2007 09:29 PM |
| electrical question | jrandalls | Ford Truck Forum | 5 | 05-24-2007 02:38 AM |
| Engine Block Heater problem 95 6.5 | GMC Smiley | GMC Truck Forum | 0 | 02-18-2007 05:03 PM |
| Engine Block Heater Problem | GMC Smiley | Chevy Truck Forum | 0 | 02-18-2007 04:57 PM |
| Question about engine block identification | iceman2007 | Chevy Truck Forum | 1 | 12-30-2006 07:57 PM |
