Old 09-02-2007, 11:53 AM   #1
Nash's Avatar
Nash is on a distinguished road
Exclamation Problem
Hey guys, I recently put a light bar and 4 lights on my 1995 F-150.
I hooked everything up like it said in the directions.
Now heres where the problem starts.
When I put the wire in the fuse box for the light switch I cant remember if i had the positive wire already hooked up to my battery or not.
But anyways the lights didnt work so i went over the whole thing again about 3 or 4 times and everything is hooked up right.
They still wouldnt work, so I thought..maybe for some reason my truck has to be on for them to work.
Sure enough when i go to turn my ignition ALL the power comes on but nothing happens to my engine at all.
The ignition doesnt click, engine doesnt even slightly turn over...nothing.
I check all my wires, every single fuse in the fuse box everything small checked out.
Any ideas? Maybe the Solenoid in the started?
Let me know if anyone has any ideas or thoughts on this.
keep in mind im more of a noob at mechanics but know base stuff.
Thanks,
NashT
Nash is offline   Reply With Quote
Old 09-02-2007, 09:31 PM   #2
Any chance that you've discharged your battery while playing with the new install ? First step, check your batt voltage. Disconnect the new wire from fuse box and check again. You may just have pushed a connection loose while doing the wiring. Can you post a simple version of the wiring part of the directions ?
Old 09-03-2007, 05:52 PM   #3
Nash's Avatar
yeah, i scan it and post it on here. thanks for the help.
ill have that up by tonight.
Nash
Old 09-04-2007, 02:58 PM   #4
Nash's Avatar
Its all good, i played around with the starter and found out that the Solenoid was fryed.
Thanks anyways
Transmission Problem z71chevy1996 Chevy Truck Forum 0 12-23-2006 04:05 PM
front brake problem 03 Ford f250 hdkidd Ford Truck Forum 2 12-13-2006 09:17 AM
'99 F250 SD with strange problem ColoQuarterH Ford Truck Forum 4 08-20-2006 10:37 AM
Hello All\help..94 Diesel Stalling Problem collision guy Introductions 3 08-01-2006 07:16 AM
Abs Problem??? MARK326 GMC Truck Forum 1 12-30-2005 01:01 AM
