Old 09-08-2007, 09:59 PM   #1
Kawboy is on a distinguished road
Brake Dust
My 1999 F-250 Super Duty has four wheel disc brakes. Correct me if I am wrong but doesn't the front brakes do most of the stopping? But even with that shouldn't I get some brake dust on the rear wheels just like the front but not as much? If I let the truck go a while without washing, the front wheels show quite a bit of brake dust but the rear wheels never show any at all. I am not concerned about the pads as there is still plenty of brake pad left front and rear with the rear shoes almost 1/3 thicker. Perhaps my proportioning valve is not doing it's job properly???
Kawboy is offline   Reply With Quote
Old 09-08-2007, 11:09 PM   #2
Oddly enough, all of my vehicles with 4 wheel discs act this way. I have two super duties and they both never show any signs of brake dust. Even my earlier trucks with rear disc conversions do the same thing. I can lock up all four wheels so I know the rear brakes are working. Pretty sure you are all right.
Front to rear pads usualy werar at a rate of 2:1.
Two replacements of the front pads to 1 for the rear. Should also not that the rear pads are quite a bit smaller than the front ones, so the amount of dust (percentage wise) would naturally be less.
If you had a problem with pressure, your multi funtion valve would activate a brake light and trip a code.
Old 09-09-2007, 07:14 AM   #3
The way I heard it explained, it has to do with a combination of static and air flow differences between front and rear.
I don't quite buy the static arguement, but the air pattern one seems like it could be.
Probably be another internet rumor before long.
Old 09-09-2007, 12:41 PM   #4
peterbilt's Avatar
peterbilt has a spectacular aura aboutpeterbilt has a spectacular aura aboutpeterbilt has a spectacular aura about
use brake dust shields. theyre like 20 bucks for a set.
1971 Volkswagen Bus Deluxe
1998 Ford Ranger XLT
"Never give up on somebody you can't go a day without thinkin' about"
Eric and Jessica 1-14-08
peterbilt is offline   Reply With Quote
Old 09-11-2007, 05:24 PM   #5
bubbas91lariat's Avatar
bubbas91lariat is an unknown quantity at this point
I have stock alloy bullet hole rims on my truck with very small holes on them. I never have a problem with brake dust on them. Just regular road grime and dirt. petes got a good idea there.
IF YOU AINT FIRST YOUR LAST!!!
bubbas91lariat is offline   Reply With Quote
Old 09-11-2007, 05:27 PM   #6
peterbilt's Avatar
and plus you can ust wipe it off, no biggie.
Old 09-15-2007, 01:14 PM   #7
you have to make sure and do it often though b4 it gets too serious then it can just be a b**** to clean off. sorry 4 the language.
Old 09-15-2007, 08:03 PM   #8
peterbilt's Avatar
ya, it could ruin ur rims.
Old 09-15-2007, 09:43 PM   #9
Moderator
i've never seen brake dust ruin rims. it might make them look bad, but they can be easily cleaned with the right detailing supplies.
member map add yourself
Old 09-16-2007, 08:11 AM   #10
peterbilt's Avatar
i have seen a car and i know the guy, and he said that it almost ruined the rims becuz it was sitting for solong, so he had to heavily scrub it off.
1949 3800 chevy panel brake dougmayer Chevy Truck Forum 2 08-22-2007 09:07 AM
Brake light problem gejandsons GMC Truck Forum 2 07-11-2007 03:37 PM
No brake lights gejandsons Chevy Truck Forum 2 07-10-2007 09:28 PM
Brake fluid tip chevyguy General Truck Forum 4 03-20-2007 08:43 AM
Which brake pads? ectech Ford Truck Forum 7 02-13-2007 10:00 AM
