| Door ajar problem Yet another problem door switch. Is there a module or relay that controls it? Thank You. |
| sounds like it could be a short. going to have to trace your wires. |
| Has this light been on since you got the truck ? With that wiring mess for the remote start you described, I'd look from there back for abuse of the wire. Was the light on when you had the switch out ? Would point to short not switch. Also depending on any alarm setup you may have, the problem could be coming from that circuit. agree with mud, nothing like looking at the wires. |
| Ok i just realized you already replaced the switch. I'm not sure if you can adjust it but might take another look at it. I bet a dollar it is the door switch. The door switch is located inside the door so you would have to remove the panel to replace. Before replacing try this. Where the metal rod runs into the door (next to the wiring harness) take some wd-40 and spray that rod and open/close the door to let the oil work in. If the light still stays on you probably need a new switch.
| Are you sure it`s the left rear??? The ford switches are on the latch as you know.. 99% of the time you can just spray WD-40 into the latch and open and close the door a few times and the switch will unstick.... |
| Yes this light have been there since the beginning. Yes there was a mess with the remote starter but I got it fixed, so I thing Thank you all for your input. |
| Yes.. that is it. It is called a vehicle security module. I controls all the generic electronic functions... door locks.. keyless remote...ect. as well as monitoring things such as door ajar. I doubt it is the module though I have seen a few fail. You will most likely need to access it for circuit tests though. Here is a copy of the circuit test procedure, I can get you connector locations at work on monday if you need them. Last edited by tjzz4; 11-03-2007 at 09:28 AM. |
| the voltage drop at the switch could be normal, hard to tell without a manual. i would stop looking at the locks and focus on the dash light. i would bet the bulb is shorted to another wire in the dash which is keeping it on. |
| OOPS... sorry... I copied the wrong pinpoint test.. Door locks are not related. |
| Here ya go... Start at H3... remember.. in step 4 there is roughly a 30 sec. delay before the lights go out PINPOINT TEST H: THE AUTO-LOCK DOES NOT OPERATE CORRECTLY Test StepResult / Action to Take H1 VERIFY AUTO-LOCK FEATURE IS ENABLED
GO to H2. No Turn the feature on with any configuration method. CLEAR the DTCs. REPEAT the self-test. H2 CHECK THE DOOR LOCK CONTROL SWITCH
GO to H3. No INSTALL a new door lock control switch. REFER to Door Lock Control Switch in this section. CLEAR the DTCs. REPEAT the self-test. H3 CHECK ALL VEHICLE SECURITY MODULE DOOR AJAR PIDS FOR CORRECT READINGS
GO to H7. No GO to H4. H4 CHECK THE SUSPECT DOOR AJAR SWITCH CIRCUIT
INSTALL a new door ajar switch. REFER to Door Ajar Switch in this section. CLEAR the DTCs. REPEAT the self-test. No GO to H5. H5 CHECK THE SUSPECT DOOR AJAR SWITCH CIRCUIT 57 (BK) FOR AN OPEN
GO to H6. No REPAIR the circuit in question. CLEAR the DTCs. REPEAT the self-test. H6 CHECK THE CIRCUIT BETWEEN THE VEHICLE SECURITY MODULE AND THE SUSPECT DOOR AJAR SWITCH FOR AN OPEN
GO to H8. No REPAIR the circuit in question. CLEAR the DTCs. REPEAT the self-test. H7 CHECK THE VEHICLE SECURITY MODULE UBP PIDS
GO to H8. No REFER to Section 418-00. H8 CHECK FOR CORRECT VEHICLE SECURITY MODULE OPERATION
INSTALL a new vehicle security module. REFER to Section 419-10. REPEAT the self-test. No The system is operating correctly at this time. The concern may have been caused by a loose or corroded connector. CLEAR the DTCs. REPEAT the self-test. |
| front brake problem 03 Ford f250 | hdkidd | Ford Truck Forum | 4 | 10-21-2009 07:59 PM |
| Doge Ram shift problem | Jake | Dodge Truck Forum | 4 | 06-27-2008 09:10 PM |
| '99 F250 SD with strange problem | ColoQuarterH | Ford Truck Forum | 4 | 08-20-2006 09:37 AM |
| Hello All\help..94 Diesel Stalling Problem | collision guy | Introductions | 3 | 08-01-2006 06:16 AM |
| 1997 chevy tahoe gage light problem | bajaboy | Chevy Truck Forum | 5 | 03-23-2006 07:58 AM |
