| Junior Member Join Date: Nov 2007
| need radiator for 66 ford. truck has chevy engine and trans. when i went to get choke hooked up, turned and saw fluid pooring onto the ground. looks like rad has a crack in the lower end. the guy at the shop said i might be able to get it repaired. if not, anyone know where to find a rad for my truck??/ |
| Many later model cross flow radiators will fit right in and work just fine. Since the vehicle has been modified already, you reaaly do not need a radiator for a 66 ford, you need a radiator that will fit. Measure the opening, and the mounting points and find one in a yard, or buy a brand new aluminum one from companies like Jegs, or Summitt. These radiators (aluminum) start at around $200.00 and are good for engines up to 600 hP's., and cool better than a conventional brass and copper radiator. I use a Jegs unit for my Ford (541 Cubic inches) and it stays cool on the street, works just fine. |
| Radiator fan | dogsrme | GMC Truck Forum | 4 | 08-16-2007 09:38 AM |
| How do I drain radiator. | jktuck | GMC Truck Forum | 4 | 01-28-2007 06:31 PM |
| 99 Dodge ram radiator help | mudbath | Dodge Truck Forum | 2 | 10-31-2006 07:17 PM |
| oil in radiator??? | s-dimeblaze-her | Chevy Truck Forum | 9 | 09-16-2006 08:37 AM |
| radiator | fatboi | Chevy Truck Forum | 7 | 09-15-2006 07:20 PM |
