Old 02-13-2008, 10:16 AM   #1
jra
jra is on a distinguished road
87 F150 won't start when raining
I have a 87 F150 with a 302 V8. When we have damp rainy weather it won't start. I thought it could be moisture in the distributor, but I took the cap off and it was dry. When it won't start I just let it sit until it quits raining and drys out, then it will start and run fine. Any ideals as to what my problem could be? Coil, bad wiring plug somewhere? Has anyone else this problem with their Ford?
jra is offline   Reply With Quote
Old 02-13-2008, 03:08 PM   #2
junior3382's Avatar
Ok bud here you go. When you open the hood, look on the fender walls. If I remember correctly, it will be on the drivers side wheel well. There is a little relay box. In there should be a plug. That is a rely for the ignition. It is a bad location due to weather, and it should have a seal. But they wear. Check that relay. If it gets wet or is a little loose, when the coonection is made to send the power to the starter, it will fail. It is an easy fix, either wipe it off and or tighten the connections. You should be fine.
Old 02-15-2008, 08:16 AM   #3
jra
Thanks for the Info Junior, I see the little box you are talking about, I'll clean the connections up and see if that solves my problem.
Old 02-15-2008, 12:30 PM   #4
keithr0005005's Avatar
if the relay wasnt the problem check your ignition wires....i had the same problem with my chevy and it was just bad wires.
Old 02-23-2008, 08:14 PM   #5
pyaaw! is on a distinguished road
another problem could be condensation getting in the plug wires, try putting dielectric grease in both ends of the plug wires.
pyaaw! is offline   Reply With Quote
F150 won't start in wet weather jra Chevy Truck Forum 1 02-21-2008 07:52 PM
1994 F150 5.0L Won't Start... TexasCowGrower Ford Truck Forum 9 01-12-2008 05:04 PM
tranny shifts funny when raining brokenbudget GMC Truck Forum 4 11-24-2007 05:53 PM
93 f150 won't start 79Bronco Ford Truck Forum 1 07-15-2007 12:17 PM
97 f150 4.2 gdog1968 Ford Truck Forum 1 12-19-2005 03:06 PM
