Old 04-05-2008, 07:17 PM   #1 (permalink)
alfonsonog is on a distinguished road
camshaft position sensor
hello guys. i have designed a antithief system for my truck, it consist in a electronic device wich disable de motor to keep it from starting, my question is, can i use the camshaft position sensor as a secret cutoff power, can i plug up a relay betwen it and the pcm to turn it off and on controlled by the antithief device, the reason for i don't want to cut the power from fuel pump or other hot wires is because most of the car stealers know how to bridge these wires, and this idea may be better, but i don't know if interrupting signals from cam sensor will cause any damage to the computer or other part of the system, can anybody help me to fix this, or can i use an other sensor to prevent motor starting? thanks.
alfonsonog is offline   Reply With Quote
Old 04-05-2008, 10:34 PM   #2 (permalink)
crabtruck is a splendid one to beholdcrabtruck is a splendid one to beholdcrabtruck is a splendid one to beholdcrabtruck is a splendid one to beholdcrabtruck is a splendid one to beholdcrabtruck is a splendid one to behold
Saying which ford you are playing with may help get better responses....
Old 04-06-2008, 08:25 AM   #3 (permalink)
my truck is a ford 1998 F150 two wheel drive, engine 4.6 L ,automatic transmission
Old 04-07-2008, 05:21 AM   #4 (permalink)
I'd be inclined not to tamper with the cam pos sensor,
there's probably a good reason why they would want to wrap those wires in a shield.
Sensitive stuff, and you wouldn't want your mod failing you at an inconvenient time.
Consider over-riding the control for the PCM power relay, lots of ways to choose from,
no sensitive signal wires, easier connections for mod.
Another thought (gloomy): if you're parking where they have time to hunt down
and rewire usual anti-thefts, they may choose to strip and destroy instead!
Good luck.
Camshaft Sensor duckshepherd Mazda Truck Forum 18 06-11-2008 04:44 PM
Throttle position sensor Robert78.5 Dodge Truck Forum 1 02-20-2008 06:41 PM
ford 3.0 camshaft synchro tool bcooling Ford Truck Forum 6 10-05-2007 08:08 PM
Help with Camshaft Legacy Chevy Truck Forum 2 03-08-2007 04:14 PM
camshaft BUCKMASTER Chevy Truck Forum 3 11-28-2006 10:16 AM
