Ford Truck Forum - Enthusiasts can discuss ford trucks, accessories, etc. |
#1 (permalink) |
03 f150 a/c question
Its my friends moms truck the ac blows cold but won't blow out of the dash vents. It will blow out of defroster and feet but not the dash. I'm thinking vaccum line. But where, and how to fix it. Any suggestions would be awesome.
#2 (permalink) |
Sounds like a clog in the ducting somewhere. Does the heater work? Does anything blow out of the vents? Could try vacuuming out the ducting, or checking fuses to the blower motors.
I would start there, it's cheapest. |
#5 (permalink) |
I had this problem with a Chevy Astro van, it turned out to bo a one way vacuum valve the vent controls are all vacuum operated and default to the defrost. it is under the hood and looks like a big diode in the vacuum line going into the firewall. Dont know if the Ford is the same but it is and easy check. Hope this helps. tom
| 93 f150 won't start | 79Bronco | Ford Truck Forum | 1 | 07-15-2007 11:17 AM |
| need help 86 f150 | patruckboss | Ford Truck Forum | 4 | 06-05-2007 08:11 PM |
| 97 F150 4x4 | Bull | Ford Truck Forum | 5 | 05-30-2007 03:57 AM |
| 95 F150 Stall | stevied | Ford Truck Forum | 0 | 12-28-2006 06:58 AM |
| 97 f150 4.2 | gdog1968 | Ford Truck Forum | 1 | 12-19-2005 02:06 PM |
