| Hesitation Ok i have 1999 ford explorer 6 cyclinder 4.0 liter that when i first start it and go to take of i have to let up of the gas pedel in order for it to engage into gear and it has a bad hesitation to it almost like it struggles to get gas and into gear |
| check this out... 1Inspect Fuel Filter Clogged or dirty fuel filter 2Inspect Fuel System Pressure Incorrect fuel pressure being delivered to carburetor or fuel injection system. 3Inspect Air Filter Restricted or clogged air filter. 4Inspect Wireset Damaged, worn, or deteriorating spark plug or coil wire(s). 5Inspect Spark Plug Fouled, damaged or broken spark plug(s). 6Inspect PCV Valve Plugged or damaged pcv valve. 7Inspect Carburetor Float Improperly adjusted/saturated or damaged carburetor float. 9Inspect Needle Seat Dirty or worn carburetor needle and seat. 10Inspect Timing Cover Stud Kit - PerformanceImproperly adjusted or worn/malfunctioning power valve 11Inspect Choke Pulloff Worn, defective, or faulty choke pulloff(s). 12Inspect Choke Thermostat Stuck or improperly functioning choke thermostat. 13Inspect EGR Valve Clogged, dirty or improperly functioning or defective egr valve.
| and this... 15Inspect MAP Sensor Improperly connected or faulty m.a.p. sensor. 16Inspect Mass Air Flow Sensor Improperly connected or faulty mass air flow sensor. 17Inspect Air Cleaner Temperature Sensor Damaged or faulty air cleaner temperature sensor or air cleaner temperature sensor circuit. 18Inspect Spark Plug Wire Loom - Performance Improperly adjusted or worn/malfunctioning carburetor. 19Inspect Oxygen Sensor Damaged or faulty oxygen sensor or circuit. 20Inspect Fuel Pump Improperly functioning fuel pump or circuits. 21Inspect Hood Brace Leaking, worn, or damaged intake manifold gasket 22Inspect Transmission Filter (A/T) Clogged or dirty transmission filter. 23Inspect Throttle Position Sensor Faulty throttle position sensor or throttle position sensor circuit. 24Inspect Transmission Modulator - (A/T) Worn leaking or faulty transmission modulator valve or vacuum system. 25Inspect Fuel Injector Plugged, dirty or poorly connected fuel injector.
| Advice needed on hesitation | Case 7230 | Chevy Truck Forum | 6 | 05-17-2008 04:35 AM |
| 1992 350 hesitation problem Help please | cobrakiwi | Chevy Truck Forum | 2 | 12-14-2007 07:08 AM |
| Miss or hesitation? | spacoli | Toyota Truck Forum | 4 | 01-06-2007 11:10 PM |
| 88 chevy hesitation | chevy_202 | Chevy Truck Forum | 2 | 11-10-2006 08:29 AM |
| 2002 chevy hesitation | mario.adame | Introductions | 1 | 09-29-2006 06:49 AM |
