Ford Truck Forum - Enthusiasts can discuss ford trucks, accessories, etc. |
#4 (permalink) |
I couldn`t find them but ford had a recall on the taurus in the late 90`s and they installed a freeze plug that had an '0' ring on it that can`t come out.. the freeze plug looked like a block heater without the element.
#5 (permalink) |
I know when I get a lot of play or a loose fit on some part that is supossed to be pressed in I take a punch and go all the way around the inside diameter and tap it. what it does is kinda distort the surface and make it "grab" the "freeze plug" in this case. I usually have to use this trick with ballbearings and races on motorcycle parts.
you could also try it with the freeze plug itself and "tap" it out so it fits way tighter in the hole. just and Idea but do what you must to get the truck back on the road
"She's gonna Freak when she see's my wheels" 85' Chevy C-10 Longbox (Rat) TBI 5.7 Liter/THM350 90' Chevy Suburban 4x4 TBI 350 Cu.In./700R4 http://www.truckforum.org/forums/truck-pictures-176.htm |
#7 (permalink) |
You'll have to let us know what he does to get it to work. I am glad you didn't go with the JB weld, that would have ruined the block if something ever happened and you had to replace that plug.
MEOW!! |
| Freeze Plugs | mxer201 | Mazda Truck Forum | 8 | 03-15-2008 07:53 PM |
| brakes freeze | ksbs2007 | Ford Truck Forum | 8 | 02-13-2008 11:01 PM |
| How do you drain the anti-freeze 95 K-1500 | larbec7 | Chevy Truck Forum | 10 | 01-30-2008 10:02 PM |
| defrost smells like anti-freeze | gustofson | Ford Truck Forum | 4 | 01-19-2007 09:27 AM |
| Anti freeze leak none on ground | 92Jag | Chevy Truck Forum | 29 | 10-16-2005 09:16 PM |
