Old 06-14-2008, 04:34 PM   #1 (permalink)
dogbone is on a distinguished road
New power booster but still hard to stop
Hello:
I put a new power booster in my ford 350 truck, a new master cylinder and bled the brakes. I adjusted the booster rod and I don't see any leaks in the vacume tube from the pump. When I press the brakes and start the car the break pedal goes down. I still have to put alot of pressure on the brake pedal though to get the truck to stop. I can't figure this out. Any ideas?
Thanks
John
dogbone is offline   Reply With Quote
Old 06-14-2008, 04:50 PM   #2 (permalink)
Chevy_Finatic79's Avatar
Chevy_Finatic79 is a name known to allChevy_Finatic79 is a name known to allChevy_Finatic79 is a name known to allChevy_Finatic79 is a name known to allChevy_Finatic79 is a name known to allChevy_Finatic79 is a name known to all
either you didnt bleed the abs if the truck is equipped I dont know what year yours is. or it souinds like a bad proportioning valve
85' Chevy C-10 Longbox (Rat)
TBI 5.7 Liter/THM350
90' Chevy Suburban 4x4
TBI 350 Cu.In./700R4
Chevy_Finatic79 is online now   Reply With Quote
Old 06-14-2008, 06:45 PM   #3 (permalink)
Moderator
mudseeker is a splendid one to beholdmudseeker is a splendid one to beholdmudseeker is a splendid one to beholdmudseeker is a splendid one to beholdmudseeker is a splendid one to beholdmudseeker is a splendid one to beholdmudseeker is a splendid one to beholdmudseeker is a splendid one to behold
how are the rear brakes, i assume they are drum type brakes. could just need to convert them to a disc setup to get the results you are looking for.
proud member of the 200k mile club
boys never stop playing with toys
Old 06-14-2008, 07:00 PM   #4 (permalink)
z07
z07's Avatar
z07 is a glorious beacon of lightz07 is a glorious beacon of lightz07 is a glorious beacon of lightz07 is a glorious beacon of lightz07 is a glorious beacon of lightz07 is a glorious beacon of light
Did you bench bleed the MC?
Old 06-15-2008, 11:24 AM   #5 (permalink)
Thanks for the replies. It is a ford f-350 one ton diesel truck, 1984. They are drum brakes that have had good stopping power up to now. I did bleed the mc. I could have done a better job bleeding the brakes though. I am going to purge all the old brake fluid from the system this time. I don't know what the proportioning valve is so I will look that up. Thanks again.
John
Old 06-15-2008, 06:39 PM   #6 (permalink)
z07
z07's Avatar
Originally Posted by dogbone View Post
Thanks for the replies. It is a ford f-350 one ton diesel truck, ...
How are your vacuum pump, storage tank, and related hoses? Any leaks, crimps, or bad haircut and sandals?
Old 06-15-2008, 08:04 PM   #7 (permalink)
z07, I will check those things tomorrow. I couldn't see anything wrong with the vacuum hoses the other day though. No bad hair cut and sandals. A hint of an attitude though. It could be partially blocked up or something. I also figured the vacuum pump was alright since I was getting a vacuum when the brake pedal went down after starting the truck up. But maybe the pump is messed up. I am going to pull the mc off and measure the push rod distance also. It looks like it is supposed to be just a hair away from the mc seat when installed.
Thanks z07
Why is vacuum spelled with two uu's. It just doesn't look right.
John
Old 06-16-2008, 04:22 AM   #8 (permalink)
leolkfrm is a splendid one to beholdleolkfrm is a splendid one to beholdleolkfrm is a splendid one to beholdleolkfrm is a splendid one to beholdleolkfrm is a splendid one to beholdleolkfrm is a splendid one to beholdleolkfrm is a splendid one to behold
Did you try flushing the brake system........Bleed it till fresh fluid is thru the system. when you were bleeding did the pedal push easy or hard when the bleeder is open?
Old 06-16-2008, 08:01 AM   #9 (permalink)
Leo, the pedal was hard to push with the bleeder open. I bled the brakes really good although I couldn't tell if the fluid was clear or not. I bled each brake about four times with good flow using up half of the fluid in the mc. What am I looking for?
John
Old 06-16-2008, 02:57 PM   #10 (permalink)
Doh!.... it looks like I had the power booster rod out to far. > : / With it adjusted in properly, I am getting help from the power booster now when I apply the brakes.
Thanks for all the suggestions.
John
Alpine V-Power Mono Power Amplifier 400 Watts model MRP-M450 with a Type E 12inch Hig Draggindime8 Truck Classifieds 0 02-20-2008 10:55 AM
O'Reilly Auto Octane booster rdillon Chevy Truck Forum 9 11-24-2007 10:02 AM
95 brake booster mbrown Chevy Truck Forum 4 04-30-2007 06:13 PM
brake booster 72'CaminoKid Chevy Truck Forum 0 08-12-2005 08:08 PM
Vacuum truck purchase approved by CN (Jasper Booster) trucknews Truck News (headlines) 0 12-02-2004 10:30 AM
