Old 06-27-2008, 08:40 AM   #1
showhaulin' is on a distinguished road
Is this normal for the truck? F350
I was checking the tran fluid and heard a clicking noise. I watched it a bit and there was a part (sorry I don't know the names) that kept stopping and starting. It was on the part that has the belt on it. I did have my Max A/C running, so I turned it off and the part that would start and stop didn't turn anymore. So I linked it to the A/C anyway. Is that stopping and starting thing normal?
I took pics, but I dont' know how to get them on here
I tried but it said my filetype exceeds the forum limit.
showhaulin' is offline   Reply With Quote
Old 06-27-2008, 09:26 AM   #2
Moderator
the stopping and starting is the A/C compressor clutch. It should cycle, but if it is cycling rapidly you might be low on freon. How often was it stopping and starting?
Old 06-27-2008, 10:05 AM   #3
I would say every 10 seconds.
I can go out and count it if you would like, LOL! No, really!!
Old 06-27-2008, 10:48 AM   #4
Moderator
no that is good enough. If it is doing it that rapidly you are probably low on freon. I would take it to a shop and have them check the freon and charge it if necessary.
Old 06-27-2008, 10:56 AM   #5
Charge what?
And is there a way I can check the freon at home?
Old 06-27-2008, 11:56 AM   #6
Moderator
You will need to have the ac system charged (re-filled) Over time freon will leak out and once it gets too low it will cause the compressor to cycle rapidly. You can check it at home if you have the proper tools (manifold and gauges). Unless you have experience with it I would suggest taking it somewhere. While not extremely high the working pressure for the high side of the a/c system is around 220 psi. I would take it to a shop and while there ask whoever if you can watch what they are doing and ask questions so you can see what is involved with the AC system.
Old 06-27-2008, 12:08 PM   #7
Will it be okay for this weekend? It is hooked to the horse trailer. It will be driven/pulling a total of 4 hours. I won't be back till sunday night.
Old 06-27-2008, 12:56 PM   #8
Moderator
it will be fine. 98 percent of the time when the motor is higher in rpms (cruising speed) the pressure in the ac system is high enough that the clutch will stay engaged like it is supposed to. it is the lower pressures while idling that cause the cycling.
98 jimmy v6 4.3 vortec normal running temp casey2008 GMC Truck Forum 1 04-24-2008 06:17 AM
Normal highway temps gmcsierra GMC Truck Forum 5 07-17-2007 04:14 PM
injectors for 03 f350 7.3 hocka Ford Truck Forum 1 03-13-2006 09:56 PM
Truck Driver Hopes for Normal Life (WXIA-TV Atlanta) trucknews Truck News (headlines) 0 08-24-2005 09:30 PM
New Silverado creaks...is this normal gerryl98 Chevy Truck Forum 3 04-10-2005 02:33 PM
