Old 06-29-2008, 03:58 PM   #1 (permalink)
1979_4x4_Plow's Avatar
1979_4x4_Plow is on a distinguished road
1990 F-150 no fuel...
let me state things i have done so far...
i have replaced front fuel pump, relay, fuel filter.
i know for sure pump is good since i used jumper wires to the pump to get it to turn on. i have used a good relay out of another vehicle that runs, but i am not getting power to the inertia switch. i think my problem lies someplace in between the relay and the inertia switch.
does anybody have a diagram of how the wiring is ran on this? i am trying to figure out if the power goes to inertia switch than to the tank selecting switch or other way around. any help is appreciated.
1979_4x4_Plow is offline   Reply With Quote
Old 06-29-2008, 07:31 PM   #2 (permalink)
would it hurt the truck any to run a new line from the relay to the inertia switch in order to get power since i think that is where my problem is.
Old 06-30-2008, 06:08 AM   #3 (permalink)
Moderator
As long as you used an inline fuse with the new wire I don't think it would be a problem. I think you can go to autozone and they will print out a wiring diagram for you...
Old 06-30-2008, 10:59 AM   #4 (permalink)
tjzz4 has a spectacular aura abouttjzz4 has a spectacular aura about
Are you aware there is only power to the inertia switch for 3 seconds after key on or unless you are cranking the engine?
Old 06-30-2008, 02:43 PM   #5 (permalink)
i had the test light hooked up to inertia switch when turning ignition to on position with no power lighting my tester.
1990 F-350 7.3 litre josnj1 Ford Truck Forum 2 10-02-2007 05:06 PM
Fuel pump, fuel tank, filler neck, filter... lassy GMC Truck Forum 6 04-11-2007 05:48 AM
1990 TBI Silverado No fuel or spark!? benjiboy Chevy Truck Forum 19 03-13-2007 09:31 PM
1990 TBI question smokensteve Chevy Truck Forum 2 03-08-2007 04:01 AM
1990 C1500 Wig Chevy Truck Forum 2 08-02-2006 04:33 AM
