Old 07-26-2008, 08:28 AM   #1
hd6b is on a distinguished road
lift kit question ?
I am planning on buying a new or newer F350 and want to fit 38's under it.I am concerned about the ride after I install a lift,not so much the rough ride over stock but the steering and wandering .I have a lifted 97 F350 and it rides real good .I have lifted others with coil springs years ago (Bronco's) and if you went more than 4" it would steer bad,also what about driveshaft angles etc. I don't really like changing u joints on the highway ? What brand lift do you recommend.
Thanks for the help
hd6b is offline   Reply With Quote
Old 08-05-2008, 06:00 AM   #2
03chevy's Avatar
have you looked at skyjacker that is a real nice lift
Old 08-05-2008, 06:04 AM   #3
junior3382's Avatar
Tough call between Sjyjacker and Fabtech..... both good lifts....
Lets get some mud on the tires...eh?!?!?
OWN:
1998 Chevy Blazer ls 4x4
4.3l Vortec V6
1998 Mazda B3000 SE 4WD
3.0L V6
3" lift
31x10.50 Liberator A/T's
Old 08-05-2008, 07:40 AM   #4
Lonesome7.3's Avatar
Lonesome7.3 has a spectacular aura aboutLonesome7.3 has a spectacular aura aboutLonesome7.3 has a spectacular aura about
It depends on what you are going to use the truck for. If you are building a concrete cowboy truck just get a cheap lift. If you plan to wheel and use the truck, I would recommend Skyjacker. What else are you going to do to the truck? I am sure you already know once you start changing things, everything will have to be changed. What gears are you planning to go with?
Oh and by the way, if you do plan to wheel this truck...
STAY A WAY FROM LIFT BLOCKS.
Old 08-05-2008, 07:46 AM   #5
junior3382's Avatar
EXCELLENT point.... check out this thread for all the answers to that topic... http://www.truckforum.org/forums/4x4...s-dont-do.html
Now I suggested fabtech due to it being great quality for solid axle lifts.... but regardless of which you want, avoiding lift blocks is always a good idea.
OWN:
4.3l Vortec V6
3.0L V6
3" lift
Old 08-05-2008, 08:16 AM   #6
Fabtech has some awsome stuff. I use to sell Fabtech kits just so I can see how they look installed. Another good one is BDS. They have a **** fine warrenty as well.
Old 08-05-2008, 07:55 PM   #7
thanks for the replies
I put a deposit on a 2006 dodge 2500 diesel today .I know why buy a dodge when all I have ever owned is Ford. Friends of mine have them and seem to have good luck .The newer F series diesels seem to have alot of problems and to find a low mileage F350 with a 7.3 is not easy.
Thanks for all your help
Jimmy
Tags
lift kit
another lift question duckkiller0010 Chevy Truck Forum 9 11-19-2007 07:40 PM
lift question duckkiller0010 Chevy Truck Forum 7 11-15-2007 09:04 PM
Lift Question Hayden Chevy Truck Forum 19 07-11-2007 04:17 AM
Lift Question.. NEED HELP chevyman_03 Chevy Truck Forum 20 05-30-2007 07:18 PM
95 Z-71 lift question alex11b Chevy Truck Forum 9 11-17-2006 12:36 AM
