| Junior Member Join Date: Aug 2008
| 98 Ranger How can I drain all of the fuel from the tank on a 98 ranger? My brother dumped what turns out to be water logged gas into it..... Last edited by psg2628; 08-06-2008 at 09:41 AM. Reason: sp |
| welcome to the forum. it you have it on the ground go to any store evan walmart and get a syphen hose with a hand pump that will work just fine.
| Welcome to the site: This comes up once in a while, and is a pretty easy fix. You can just drain from the bottom of the tank if the tank is already equiped with a drain. Most are not, so adding one might be an option. It was suggested that a siphon is used, and this is a great idea. If you can siphon from the bottom of the tank, you can pump out every bit of water before it starts to pump gas. Water is heavier (more dense) than gas, and the water will seperate, and will be at the bottom of the tank. Since liquid finds its own level, and these two liquids will seperate, it is entirely possible to remove the water, and leave the gas. Even if you shake the tank, it will eventually seperate and you can safely remove the gas from the tank. Slight word of caution, is that some static electricity is generated during the siphon process, and if you use an electric pump, you just want to make sure that you are not creating sparks. A cheap electril pump can be used, and is easier to run 3/8" rubber hose through the filler neck. Larger hoses are often difficult to get into the filler. Pretty simple to get water out of a tank. Good luck. |
| Senior Member Join Date: Jun 2008 Location: Columbia Falls, Montana
| Do NOT use a vacuum. Get a hand siphon, as suggested. Or, also suggested, a drain on the tank. If I'm not mistaken, there is one on the passenger side of the tank on the Ranger (well, I shouldn't say there is, as Rangers used about 4 or 5 different sized tanks in the trucks).
__________________ 1992 Ford Ranger 4.0 XLT super cab 4X4 auto. A few mods, but it's not finished yet. 1995 Dodge Ram 1500 single cab short box 318 5 speed manual. The work rig. |
| 150 -> ranger | liftedtrucks4me | Ford Truck Forum | 4 | 03-24-2008 10:49 AM |
| 97 Ranger | leanne | Ford Truck Forum | 8 | 01-10-2007 05:19 PM |
| 97 ranger | ranger97 | Ford Truck Forum | 13 | 09-11-2006 05:59 AM |
| '89 Ranger | kc7taf | Ford Truck Forum | 4 | 07-10-2005 01:40 AM |
| 84 ranger | 84ranger | Ford Truck Forum | 2 | 05-12-2005 03:49 PM |
