| exhaust bracket i have truck exhaust stacks on my truck and drilled 4 holes for a bracket to help brace it, i took off the interior on the back of the cab on the inside and still can't see the holes, is there any easy ways to expose the holes with out ripping too much up, any suggestions. |
| hidden holes you might have a double panel ,you might have to use nut zirts to fill the holes with threads ! ![]() |
| take a wire coat hanger and feel around but it is a double panel... |
| and i guess to make it more difflicult that there is no way to take the double panel off easily |
| nah it is part if the structual integrity.... zirt nuts work really good for sheet metal but for exhaust i dont think they would hold up... maybe get a longer drill bit and drill through the second panel and longer bolts |
| Ok, i think that is what I'll do, thanks guys |
| a bracket on my truck frame is bent how can i fix it | shaunweldin | Off-Topic | 3 | 06-05-2008 05:15 AM |
| bent control arm bracket/frame damage how can i fix it | shaunweldin | Dodge Truck Forum | 0 | 06-03-2008 12:24 PM |
| 7-pin mounting bracket needed | jklingel | Chevy Truck Forum | 3 | 02-21-2008 11:42 AM |
| Bracket Nightmare | BillySuburban | GMC Truck Forum | 5 | 03-09-2007 10:44 PM |
| Removing AC Bracket - 1990 Scottsdale 4x4 | Jesauls70 | Chevy Truck Forum | 1 | 02-04-2007 06:28 AM |
