| coolant overflow I just came home from school and i back up a hill to park in my driveway, i was with my girlfriend and showing off and spun tires up the hill, when i parked it my overflow coolant bottle poured out. What does this mean? Is it bad? What do I need to do to fix it? |
| What year truck how many miles have you ever had the radiator cleaned out what have you replaced in the cooling system? |
| Senior Member Join Date: Dec 2006 Location: Illinois
| did it pour out? or did it look like a volcano? what color was it?
__________________ Ashley My first truck was a 1988 Chevy 1500 with the 305 My new truck is a 1997 GMC 1500 with the 350 |
| its a 86 ford f150, 351, flushed the radiator last march or april it was a volcano coming out and it was fizzy and foamy until it hit the ground then regular antifreeze color |
| Check your thermostat see if it's not stuck closed might just change it and if it's old, also check your lower radiator hose make sure it's not clasping even a bad radiator cap will fool one good also check your fan clutch. Keep us posted. |
| i will look at all that but i put brand new upper and lower radiator hoses last spring, when i first got the truck i had coolant problems so i changed the hoses for sure but i will check the thermostat |
| First you can't impress a girl with a ford! sorry had to do itit sounds like the cooling system is marginal when you put a load on the engine, look at the fins in the radiator especially the bottom half, lightly rub you finger on them and see if they are soft, the radiator may not have enough cooling capacity left for a heavy work out. look inside and See how well the coolant is flowing,
| my past issues have always lead to the thermostate or rad cap... if the thermostate is stuck closed then the antifreeze inside the block with expand alot when it gets hot and the water pump spins faster then normal... but if the rad cap isnt providing a good seal then when the system starts to pressurize then it will just go directly into the overflow and youll see that volcano.. both are a cheap fix so you should be spending more then 40 bucks combined and it will give you a little more security next time you try to impress the girl with a ford...lol |
| last time i seen that was an overheated engine. |
| Forgot to mention if you have driven in mud or weeds the bottom part of your radiator might be dirty that can cause it from not cooling correct. |
| Low coolant | stelmadl | Chevy Truck Forum | 14 | 03-15-2009 07:18 AM |
| coolant leak | mitchp420 | Chevy Truck Forum | 12 | 04-13-2008 04:18 PM |
| more coolant fun :( | keithr0005005 | Chevy Truck Forum | 4 | 01-28-2008 08:04 PM |
| Oil in my coolant | dhashigu | Chevy Truck Forum | 15 | 08-07-2007 01:29 PM |
| Low coolant | TLing56 | Chevy Truck Forum | 1 | 05-25-2006 03:36 PM |
