Old 11-11-2008, 10:59 AM   #1
petey gmc is on a distinguished road
diesel wont start when warm?
Have a 2004 ford diesel and it starts great when cold but once it has warmed up and you shut it off ...it wont start but if you let it cool off it starts fine?....any ideas?
Thanks
petey gmc is offline   Reply With Quote
Old 11-11-2008, 11:53 AM   #2
I am gonna go out on a limb here and asy that this could be the HPOP.
There are a few other possibilities, but high pressure oil is the common problem here.
Sounds as though you have a high pressure leak, or faulty pump.
Not fun!!!
Old 11-11-2008, 12:49 PM   #3
tjzz4 has much to be proud oftjzz4 has much to be proud oftjzz4 has much to be proud oftjzz4 has much to be proud oftjzz4 has much to be proud oftjzz4 has much to be proud oftjzz4 has much to be proud oftjzz4 has much to be proud of
I agree with 75 assuming it DOES crank over...
Old 11-11-2008, 01:21 PM   #4
yeah I'm thinking something with the ICP as well...
If it is the PUMP itself I hope you have a warranty. Most places will pull the cab to replace the HPOP on a 6.0...
Old 11-11-2008, 02:31 PM   #5
Ya it does crank over
Old 11-11-2008, 02:32 PM   #6
it will start with starting fluid
Old 11-11-2008, 02:49 PM   #7
Yeah... As long as the valves are opening and you have some compression that will make it start... You need to get in there and look at ICP with a scanner while cranking. Oil change interval OK?
Old 11-11-2008, 05:30 PM   #8
oil chnge interval is ok....thanks guys ill check it ouy
Old 11-11-2008, 11:15 PM   #9
What is the criteria for the ICP? Some 300 PSI right?
Only a quality scanner will tell you what the potential problems could be, but unfortunately, I am still thinking HPOP.
I wish I was a better diesel mechanic. Always something to learn....
Please advise. This will eventually be a topic that will benifit a future user that uses the search function.
Old 11-12-2008, 11:36 AM   #10
ICP need to see 500 PSI before injectors are enabled. There could be several contributors here... faulty ICP sensor.. Failed IPR.. Or.. as you say.. HPOP could very well be the culprit.
Chevy diesel 3500 HD wont move dspabout Chevy Truck Forum 6 10-23-2008 04:47 AM
wont start at first tnbuckrut Ford Truck Forum 3 12-19-2007 08:38 PM
hard start when warm ike77 Chevy Truck Forum 4 12-08-2007 10:46 AM
83 gmc wont start joeydeherrera54 GMC Truck Forum 7 11-28-2007 03:30 PM
truck wont start when warm redneck Ford Truck Forum 4 04-21-2007 05:16 AM
