| Full Member Join Date: Sep 2006 Location: Manitoba
| 5" versus 4" exhaust A freind of mine has a Ford 2005, he wants to change exhaust and get rid of cats. He wants good fuel economy. He has the hi flow air filter and an Edge Box, is he better to go to 4" or 5" exhaust? The truck is used for his 5th wheel camper. It is diesel Last edited by Robert78.5; 11-27-2008 at 07:04 PM. |
| I would go with 5. More air flow through the pipes and its a little louder which is cool. |
| im assuming its deseil.. if it is then go withthe 5s... they sound nasty |
| 5" won't do anything except lighten your pocket book more. You will have no more gain (performance wise) over the 4"
| I would check with customer support at edge, tell them what you have and ask what you can do
| | #6 | |
| Banned Join Date: Nov 2008
With the stock turbo and a (relatively) stock truck the 5" will not help perfomance any, and with the catalytic converter removed might actually hurt it. Turbochargers need a certain amount of back pressure to fuction properly, and in this case, bigger is not better. A 4" exhaust will work just fine. | |
| | #7 | |
PRECICLY! unless it it heavily modified, 4" is the way to go dude....
__________________ SUPERCHARGED 454 K2500 GMC! 450hp and 600ft/lbs http://www.youtube.com/watch?v=WJ27RJHfJKE "sailing with Captain Morgan often!" | |
| Senior Member Join Date: Oct 2008 Location: NW Arkansas
| 4" with stacks through the bed!
__________________ http://s513.photobucket.com/albums/t...t=HPIM1105.jpg '76 Silverado10 Custom Deluxe, 350 4barrel, th350 auto FULL TIME FOUR WHEEL! |
| I agree with merlin here, you need to consider the backpressure. ESPECIALLY when running a stock turbo setup. If you are trying for better mileage, try upgrading the whole air flow system front and rear. Allow it to breathe better, but I would not remove the cat. I would also check out bullydog, they have some excellent upgrades for disels and the cost is reasonable. Not to mention the power and mileage increase, especially for towing.
| my 05 F550 gained 1 mpg without its cat, plus then the turbo is REALLY loud, BUT THE EXHAUST REAKS, it`ll K.O. you in no time!
| Tags |
| exhaust |
| 2008 chevy 1500 with 2.5" level kit and 3" body lift | bigohagen | Chevy Truck Forum | 6 | 06-04-2008 10:33 PM |
| "No-Drone" exhaust for Duramax | Russ Weaver | Chevy Truck Forum | 2 | 02-16-2007 01:43 PM |
| The "lift bed" Procedure for R&R tank mounted fuel pump? | Shox | Chevy Truck Forum | 4 | 02-16-2007 12:01 PM |
| S10 Intermittent "overnight" no start continues ,need help from electrical Guru | STRAYDOG | Chevy Truck Forum | 11 | 11-09-2006 03:59 PM |
