| Senior Member Join Date: Jun 2007 Location: West Texas
| Taking gauge cluster out i am wanting to know how to take the gauge cluster out of my 06 F250. i am wanting to clean the inside side of the lens because its real dirty. any tips would be appreciated. |
| most trucks i have worked on, the trim piece around the cluster pops right off, there may be a screw or two holding it tight right by the cluster. once that is off, there is probably 4 screws holding the cluster to the dash.
| Here ya go... No need to upload configuration unless you are replacing it. Instrument Cluster Finish Panel Printable View (109 KB) Removal and Installation
Instrument Cluster (IC) Printable View (183 KB) ItemPart NumberDescription1 N807122 Instrument cluster (IC) screws (4 required)2 7B053 Transmission range indicator (if equipped)3 — Instrument cluster (IC) electrical connectors (2 required) (part of 14401)4 10849 Instrument cluster (IC) Removal and Installation
| thank you i got it done it was simple. i appreciate it. |
| Gauge Cluster Mods....got some q's | xfactor | Chevy Truck Forum | 7 | 12-08-2008 06:05 PM |
| gauge cluster problem in 89 chevy | Diesel_Fan | Chevy Truck Forum | 1 | 10-13-2008 06:16 AM |
| gauge cluster swap? | cburcham73 | Chevy Truck Forum | 6 | 08-29-2008 08:59 AM |
| won't run with gauge cluster replaced | t3952 | GMC Truck Forum | 0 | 06-10-2008 08:03 PM |
| Gauge Cluster Question??? | 92BlueZ71 | Chevy Truck Forum | 6 | 12-04-2006 08:22 AM |
